5 speed /62 chev car bell hsg.
Discussion in 'The Hokey Ass Message Board' started by FOURTYDLX, Jul 22, 2013.
  1. FOURTYDLX
    FOURTYDLX
    Can I use a62 chev p***. bell to a s10 5 speed?
  2. 57 HEAP
    57 HEAP
    I say yes. The ****** to bellhousing bolt spacing is the same, but the holes in the ****** are metric and must be opened up slightly. The '62 flywheel and throwout bearing should also work. The only difference will be in the clutch disc, IF the spline count is not the same.
    The other thing to look out for is crossmember location.
  3. switchkid0
    switchkid0
    Isn't there also an issue with input shaft length? Thought I read where you could either trim the input shaft slightly, or there is an adapter/spacer available.
  4. El Caballo
    El Caballo
    from Houston TX
    GlassThamesDoug likes this.
  5. FOURTYDLX
    FOURTYDLX
    Guys: Thanks for all the replies. Going in 32 roadster.
  6. switchkid0
    switchkid0
    Thank you El Caballo.
    It's such a good feeling to have remembered something correctly.
  7. scrap metal 48
    scrap metal 48
    I think this is the same bell housing, from a 66 truck..
