Need some help Identifying a Frame:
Discussion in 'The Hokey Ass Message Board' started by MrRoach Sir, Jul 21, 2013.
  1. MrRoach Sir
    MrRoach Sir
    from Mexizona
    I acquired a project with a 10 bolt chevy rear, dropped axel I-beam front end, a RATTY pieced together T-bucket body and a frame that someone added a back half on. The guy told me it was a '32 front section with a homemade back half. The ***le was for a dune buggy with numbers matching nothing on the car anywhere. With the body off and checking the frame I found numbers stamped on the left rail under the front of the cowl.
    They read (quotes mine) "*-52****6*" Instead of a letter prefix it looks to be a "dash". The dash is somewhat indistinct but there is a definite space between the star and the first number. Like to sort this out before I goto the DMV...any ideas?
  2. 117harv
    117harv
    Sounds like a model A...pics?
  3. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Dunno how to post pics here yet? Also the numbers seem to be too high for a model A.
  4. Fenders
    Fenders
    Yes too high for a Model A.
  5. F&J
    F&J
    Go to the bottom of this page and it says quick reply or go advanced.
    Click go adv
    then on that new page, click Manage Attachments.
    I bet you can figure it out from there.
  6. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Here's the vin. If I look at T numbers it puts it around 1922?
  7. MrRoach Sir
    MrRoach Sir
    from Mexizona
    I'm thinking may or '22. Only thing that throws me is the "Dash" in front of the numbers.
  8. Supposedly Model T has no numbers stamped on the frame, just the motor block.
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Model Ts did not have frame numbers untill 26-7 and then not all had them.
  10. thunderbirdesq
    thunderbirdesq
    might be easier to identify if you post a couple pics of the whole frame?
  11. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Only thing orig is the front 1/3. They off the car now for some frame tweaking but i'll post the sections. hamb won't let me post pics at this moment but I'll get them on here.
  12. The37Kid
    The37Kid
    999 out of 1,000 HAMB members ID frames from photos not numbers. Bob
  13. are the front end of each frame rail rounded off[model A] or cut "square" off?[others]
  14. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Appears to be tapered towards the front. With is 35" at the cut and 27" where it curves down. appears to be rounded frame ends. Pics should now be up. I have already posted a partial vin.
    ok I hadda shring the hell outta the pics but they are there.
  15. kracker36
    kracker36
    Looks like a 32 maybe.
  16. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Dunno, is this what ya called squared off? More like angle cut? An they don't appear cut either. If needed i'll get some close up frame end today.
  17. MrRoach Sir
    MrRoach Sir
    from Mexizona
    @Kracker...the frame numbers don't run that high for an "A". Truck maybe?
  18. alchemy
    alchemy
    Itsa 33-34 big truck. The kind that usually has a straight rail from the cowl to the rear.
  19. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Any idea where I can find a vin sequence for it?
  20. Bruce Lancaster
    Bruce Lancaster
    From what I can see, I think Alchemy has it. span between mount holes would help confirm '32-4ness.
    Serial sounds right for a Model B, so for a big truck full number would have been
    *BB-5,**x,**x*
    The serial would nail the original year...I think nearly all '33-4 B's were in the 5,200,000 range. Model B serials started at 5,000,000, to put them solidly beyond the A series.
  21. Bruce Lancaster
    Bruce Lancaster
  22. MrRoach Sir
    MrRoach Sir
    from Mexizona
    No letter pefix
    <table><tbody><tr><td style="background-color: #ffff9c;">B, BB</td> <td>5234548</td> <td>-5241341</td> <td>August 1933</td></tr></tbody></table>
    could be 33-4 roadster, coupe or truck.
    Bottom third of page:
    http://www.fordgarage.com/pages/ABenginenumbers.htm
    <table height="24" width="1"><tbody><tr><td style="background-color: #ffff9c;">B, BB</td> <td>5234548</td> <td>5241341</td> <td>
  23. alchemy
    alchemy
    Don't think that's a p***enger car frame.
  24. Doesn't the dipped spreader bar mean big truck?
  25. Bruce Lancaster
    Bruce Lancaster
    It's a big truck, BB, not a car.
    Same engine, the power unit as it left the factory would have had the BB # on the bellhousing.
    This was stamped onto the frame at ***embly line, it is only mildly unusual for the prefix to be missing from frame.
    The prefix went onto the engine itself because as a truck it would have had the 4 speed trans attached...engines of a given type all got #'s from the same series, the prefix marked them for the right application on the line.
  26. MrRoach Sir
    MrRoach Sir
    from Mexizona
    Seems to show August '33. Probly makes it a '34. Unless they have a record of that vin I'll re-***emble it by next year and try to convince the dmv up here in Nowhere, az that itsa '34 roadster. Sell my steel t-body an find a roaster bod.
  27. Bruce Lancaster
    Bruce Lancaster
    Serial would have been the same if that engine had been put into a roadster except for the "BB" vs "B" prefix...and you don't even have a prefix, so just report the number as B -******x
    And if you met up with a devious person with Ford stamp set...you did say there was some space after the star...
  28. I believe that is a big truck rails also.....that would make it amost a1/4" thick as opposed to about 1/8" on a car frame in '32- '34
  29. MrRoach Sir
    MrRoach Sir
    from Mexizona
    It measures 1/8 thick. nevertheless lacking actual model designations I'll try to convince them itsa car. Unless of course the vin jumps up with some sort of record.
  30. Bruce Lancaster
    Bruce Lancaster
    It is absolutely for sure a big truck frame. The serial should not pop up since the vehicle no longer exists and you have the numbered part...but remember it should only pop up as BB####...if a single B were to accidentally appear in the space you mentioned, or if you should happen to screw up and leave one of the B's off of your application form...
    B### never even existed, so could not pop up! You would accidentally find yourself owning an entirely fic***ious car with a serial number that is all yours.
