Welding Please
Discussion in 'The Hokey Ass Message Board' started by syndromeofadown, Jul 22, 2013.
  1. syndromeofadown
    syndromeofadown
    from Tacoma
    Any info on good source to learn welding basics, i.e. type of welder for the occasion. Any books/video that is highly recommended would be awesome.
    No time for lengthy school, or cl*** just like to learn on me own time.
    Thanks for any advise:eek:
  2. Your here. Do some searches. Read. Practice on s**** not your car.
  3. chafin
    chafin
    Hobart welders come with a basic how to weld booklet with there welders. You can also go to any of your local book stores and they will have How To Weld books. Also, check out Youtube it will at least get you some basics
  4. lowcoe
    lowcoe
    Try typing welding on the HAMB.
    (Curtis HS cl***of 89)
  5. crminal
    crminal
    Excellent! So much here available through the search feature
  6. SCtattooer
    SCtattooer
    autobody101.com has a ton of info for beginner welding also
  7. 29AVEE8
    29AVEE8
    What type of welding? AC stick, DC stick, OX/AC, Mig, Tig, ? Much to learn regardless. Many on here can help with whatever type, but you need to give more info including material type and gauge.
  8. Deuce Daddy Don
    Deuce Daddy Don
    There is nothing like "Hands on" for learning any type welding.
    Take a course at your local Community college. You will never regret it.
    I have taught some, including fellow "helpers" in the pipe trades, my son, & grandsons.
    Welding since 1951(USN)---Don
  9. aaggie
    aaggie
    Go to www.weldingtipsandtricks.com. Jody Collier has an archive of videos of welding tips and if you sign up for his E-mail they will send you the weekly tip video. It's free and well worth the time.
  10. 1971BB427
    1971BB427
    from Oregon
    If you're in a hurry, and you want to self learn, then I would suggest you start with looking at MIG tutorials, and plan on getting a MIG welder. Probably the easiest method of welding to learn from scratch.
  11. oj
    oj
    get a good machine and have at it. The key is a good machine. You got to make a lot of mistakes and screw **** up before you'll understand the advice.
  12. christurney=77
    christurney=77
    from neosho
  13. ems customer service
    the lincoln electric company has some good books via the" james lincoln foundation"
  14. lownslo50
    lownslo50
    from Florida
    Practice,practice,practice.
  15. Pops1532
    Pops1532
    from Illinois
    What are you planning on welding? If you plan to weld frames or suspension brackets you should take a cl***.
    I've seen guys go out and buy a MIG and lay down some good looking beads but they were cold lap and you could knock them apart with a ball peen hammer.
    There's really no subs***ute for good instruction and lots of practice. Night cl***es at a community college would be my suggestion.
  16. black 62
    black 62
    from arkansas
    follow the puddle , works for all types of welding...
  17. ParkinsonSpeed
    ParkinsonSpeed
    Figure out what your going to be welding.... Get a welder that will weld all of it... You Tube. As mentioned welding tips and tricks... There is a kid on there with the username ChuckE2009 that pretty much made videos from the start of his backyard welding carrier and will give you some insight. Practice makes perfect and even try to find a local buddy that can show you some hand on welding and fabrication.... Fabrication is more important than welding because if its not prepped or fitted right it will never weld the way you want it to. And the most important thing is don't be afraid to ask, as you already have. Good luck!
  18. rustyangels
    rustyangels
    Use 1/4" s**** and bend the welds in a vise. Besides teaching yourself, who's gonna critique your welds? Some high schools offer night sessions
  19. Dane
    Dane
    from Soquel, CA
  20. BACAGrizz
    BACAGrizz
    I took a home and farm welding course at the local vo-tech for a refresher. Evening adult education course. It en***led me to discounts at a local welding supply store and that's where I scored a nice plasma cutter and self darkening hood.
  21. 123
    123
    from Seattle
  22. no55mad
    no55mad
    Good advice
  23. 1971BB427
    1971BB427
    from Oregon
    And I've seen welds that wouldn't break apart, but had so much penetration that adjacent metal was the weak point. Need to learn what is right, and not have the welds too cold, or too hot. Either can be bad.
  24. mashed
    mashed
    from 4077th
    My reference.
    I prefer old text books. You know, the ones that don't need a power supply or an internet connection.
  25. syndromeofadown
    syndromeofadown
    from Tacoma
    Thank you everyone for the advise!! Night cl***es, books, practicing and further research on this site should be beneficial.
    Thanks!!
  26. chopolds
    chopolds
    from howell, nj
    In your first post you seemed very impatient to learn....not good in a field like welding!
    I'm glad you took the advice to look into taking cl***es on how to do it right. Often videos, learning from friends, and such, you don't learn the theory and metallurgy components that you need to understand the welding process. Good luck!
  27. woodiewagon46
    woodiewagon46
    from New York
    I have been welding since 1965 and p***ed the test for my New York City, Cl*** 1 welding license in 1980. If you are in the market for a machine I would suggest a Lincoln or Miller machine. Millermatic 180 or 211 have "Autoset" that will set your wire speed and amps for you. You can learn the basics but in the end it comes down to practice, practice and more practice. After you get comfortable with MIG you can progress to TIG. ARC (stick) is the hardest to learn but a MIG will suit you fine for car work. If you are going to NSRA Louisville you can play in the Miller Electric with their products.
