1936 Ford 3 window build
Discussion in 'The Hokey Ass Message Board' started by 32fivewindow, Jul 16, 2013.
  1. 32fivewindow
    32fivewindow
    from USA!
    36 3 window
  2. tinmann
    tinmann
    Good project. I think I'd be beating the bushes trying find tudor doors. Making 5w doors into 3w doors sounds like way too much work.
  3. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    Looking forward to watching this one go together. Please take/post a lot of pictures of the how you do the doors.
  4. brady1929
    brady1929
    Sweet hot rod
  5. chevy54man
    chevy54man
    from NC
    Wow, great job on a killer car!
  6. on the car in my avatar the p***enger door is a tudor sedan door with a 3 window door top welded to it
  7. 32fivewindow
    32fivewindow
    from USA!
    Very cool, I wish I had actual 3 window tops but those seem like a unicorn at this point.
  8. milkweed
    milkweed
    from SLC UT
    I might have some unicorns in my garage......
  9. dropped axle , split `37-`40 bones , Posie reverse eye spring
  10. 32coop
    32coop
    from Australia
    I love 36's subscribed.
  11. ironandsteele
    ironandsteele
    I'm jealous. Great project.
  12. FalconMan
    FalconMan
    from Minnesota
    nice work so far.... keep us posted !
  13. FalconMan
    FalconMan
    from Minnesota
    Great work.... but now that I see the side profile, something about it looses the great lines of the 3 window...
    Did you start with a 3 window or 5 window roof ? The upper doors and the rear roof loose the curves the 3 window is known for....It depends on what 'look' you are going for.... Not sure if you had a pattern or just making what you have work together....
    Not a criticism... just an observation ...
    As far a modifying the firewall, its a tight fit. I have seen it done with no cutting. I cut mine 4 inches to make it 'easy'.
  14. alchemy
    alchemy
    It looks like you cut the back of the roof at 10 or 11 o'clock, when it should have been cut at 9. I'd look for some chunks of another roof to see if you can get the "flow" back.
    I've never heard of somebody chopping the doors first, and then bringing the roof down to match. That may have been where the "uniqueness" of your chop came in.
  15. Itchy-Pit
    Itchy-Pit
    Subscribed! I may be PM'ing you about dimensions etc for my build. In my album.
  16. alchemy
    alchemy
    I also put together bodies from s****s, so I'm not critisizing. I'm just pointing out what I personally saw as a flaw that would be easier to fix now than later. If you like it how it is, then all the better for you. I'm just used to the cl***ic way that 36 3-windows get chopped.
  17. 40mercFlathead
    40mercFlathead
    Keep it up man, you're doing a great job.
  18. 32fivewindow
    32fivewindow
    from USA!
    Have been busy stripping and pounding out dents, re-doing/finishing some welds from the cars former life.
  19. ESGEE
    ESGEE
    from Sweden
    Look to tight. Subrscribed for sure...
  20. threewindaguy
    threewindaguy
    You can put a small block in without modifying the firewall. It's TIGHT, but it works. Mine has been in for fifteen years.
  21. rustryder
    rustryder
    from Dinuba ca
    you can put a hemi in it but the firewall will never be the same. user79745_pic212391_1282633899.jpg user79745_pic254489_1294988212.jpg
