Guys I have a 64 ford with a c4 ******. I recently reinstalled the 170ci I6 motor with the ****** attached for ease of installation. Went to hook up the drive shaft, but the damn yoke is stuck in the rear of the trans. Has to be the splines. Ive tried tapping it with a hammer, pulling it with a chain. Its seized pretty good. any ideas before I drop the ****** and take it to the shop? Im not a transmission guy, ive dropped them before for clutch repair. Ive installed new drive shafts etc, but the stuck yoke is a 1st for me. ~Ray in Texas.
I have only ever seen this situation once before and I finally just drove the spined yolk out of the ****** only to find the output shaft had somehow been damaged and the yoke and shaft were slightly bent. Ended up taking the ****** (51 Ford) apart and had the shaft staightened and replaced the yoke. You don't mention why the yoke was in there in the first place, did you get it like that? Could it be someone forced the wrong yoke in there in the first place?
Slide hammer? If not, then pull the freeze plug out of the middle of the yoke and install a gear puller somehow and try.
Original trans to the van. When I removed the motor and trans from the van the yoke remained in. Should have known then I had a problem, but my focus was the motor at the time. It sat over a year without running, somehow seized over that time.. Looks like I will be dropping the trans..
I had one that actually welded it's self to the output shaft because it got so hot but I'd suspect that this is probably rust or varnish holding it in. I'd try gentle taps with a bfh if you haven't already done so.
I'm giving it ago later after work to see what happens.. These cl***ics love throwing curve balls and you.
how did you remove the driveshaft and leave the yoke in the trans. Sounds like someone jammed the yoke back in after removing the u-joint.
I suspect he did it by removing the u-bolts that hold it on to a fixed yoke on the output shaft. May also explain if it has a splined slip driveshaft. My kid's '63 did........
It does have a damn hex head. Got it fixed. Learn something new everyday I get underneath this van. I thought this entire time the yoke was a slip yoke. Its is not. The damn drive shaft flexes at the end like a shock. Simply had to pull on it and presto it fit. I've had a few cars and this was a first without a slip yoke. Figured it out with the help of my neighbor.
It is really great when someone posts the solution! So many times on here we are left hanging because what ever the right answer was they don't let us know.
