Hello all I have a 1937 Buick special model 48 2 door I'm looking to Lower it a few inches front and rear looking for some ideas on how to do so without affecting the ride to much and not getting into a big project. Please give me your ideas and what you have done with your cars thanks.
I don't mind being on the cheap but with this car a rather spend a little money and get it done right...
Coil Spring Specialties can custom wind you a set to your specifications: http://www.coilsprings.com/classic.aspx Does your car have coils or leaf springs in the rear?
37 has leafs on the rear, so 2" blocks will get you the 2" drop. Fronts I would cut a coil and go from there. I went a different route.
looks good buddy I'm looking for a little bit lower so probably will do 3 inch blocks in the back. Not sure about the front yet maybe drop uprights from fatman fab
