Projects 41 plymouth coupe 392 hemi build thread
Discussion in 'The Hokey Ass Message Board' started by farmer12, Apr 7, 2010.
  1. zibo
    zibo
    from dago ca
    Hey Farmer.
    You are lucky to be smart and route all the lines before the body is mounted.
    I ran out of time and now get to roll around on the creeper.
    No big deal until you see how easy it is looking at your pictures!
    Great to see that chop mess all fixed up.
    Must be nice that you are on the home stretch.
    Good to see some updates!
    Wish you were closer would be fun to see our cars (chopped 40) side by side!
    TP
  2. farmer12
    farmer12
    Thanks zibo! The essential part now is not to forget anything. (And I'm sure I will somewhere down the line). I try to write everything down that comes to mind, no matter how small. Glad you're enjoying the build!
  3. farmer12
    farmer12
    Thanks Antti. If ever I need any more nuts and bolts, that could be another good source. Thanks for the advice.
  4. Baumi
    Baumi
    That´s an awesome build your doing. Great to watch!
  5. farmer12
    farmer12
    Thank you Baumi! I stay in Landshut (Munich) a few times a year. Great ****tail bar on the first floor in the centre square!
  6. Baumi
    Baumi
    That´s cool! You ought to be here right know, people are getting crazy at the mideval festival we have here right now! Would be great to meet you, maybe you could give me a heads up when you´re in around here again! I´ll pm you my #
  7. Baumi
    Baumi
    BTW, I wish I had a Hemi in my Plymouth too, but youknow, always a minute late or a buck short:) Mostly both
  8. farmer12
    farmer12
    This is going to be the last progress report before I go on holidays. Fitted the main fuel line from the pump all the way to the top of the c-notch. From there it will connect to the fuel cell located in the trunk.
    Next was to find a location for the vacuum pump. (I won't be using vacuum from the engine for my brake booster.) I found the perfect position between the frame rails, allowing me to run the hose along the body (inside the front fender) to the brake booster located underneath the dash. I know, I know, a lot of work just for aesthetic reasons.;) I got a little arty on the shape, deciding it just looks better this way rather then cutting out a boring square. Drilled the mounting holes through the frame and used rubber pieces to limit the vibrations. Job done!:D:D:D
  9. davo461
    davo461
    Hi ! Eric, is that copper brake line I see?
  10. farmer12
    farmer12
    Yep, it's copper.
  11. davo461
    davo461
    Well, it doesn't look like it's going have a vibration problem, what with all the mounting points.
    Nice to see the build continuing with aeronautical precision.
    Davo.
  12. 48plysled
    48plysled
    Getting excited to see your 41 getting closer to color. Inspirational for me to get back out and plug away on my 48. Think this weekend will be a good time start back up on it.
  13. robleticia
    robleticia
    Hurry up!!!! I want to see some paint!!!!
  14. dirt t
    dirt t
    Is that vacuum pump vacuum operated or is it electrical ? What's it out of ?
    Thsnks
    dirt t
  15. langy
    langy
    Eric I'm sure you know what your doing but is that copper or kunifer ? Personally I wouldn't use copper, seen it fail a few times
  16. art.flame
    art.flame
    Steve i'm sure Erik is using kunifer copperbrakelines are illigal and therefor not sold in automotive stores ,peronaly i'de rather use stainless
    btw your on a roll Erik
  17. langy
    langy
    Art didn't know copper was illegal in Holland, It ought to be illegal here but still people use it.
    I guessed Eric would have the right stuff but thought it wise just to check.
    Yeah I'm surprised he isn't going with stainless but Kunifer is top quality stuff also.
  18. OahuEli
    OahuEli
    from Hawaii
    What the heck is Kunifer?
  19. joco
    joco
  20. langy
    langy
    It's a mixed alloy tube used for brake pipes, it's a mixture of copper and nickel, very strong and corrosion resistant, probably about the best pipe to use for brakes, Volvo were the first big car company to fit it in the 70's
  21. OahuEli
    OahuEli
    from Hawaii
    Thanks joco and Langy I appreciate it! I'm pretty familiar with copper-nickel and can appreciate the properties. Never knew brake line was made from it but it makes perfect sense.
  22. farmer12
    farmer12
    As if I don't want to see some colour............I know it's getting close, but I want to make sure I've covered everything before it's paint time. Don't you just hate guys with sooooo much patience? :D:p
    Seriously though, this year the car will have paint on it. (and honestly, I can't wait either.)
  23. farmer12
    farmer12
    The vacuum pump is electrically operated and keeps the vacuum between 18-22 psi if I recall correctly. It shuts off at 22 psi and comes on when the vacuum drops below 18 psi. The pump is from SSBC. Apparently it's fairly noisy but I'm ***uming that the 392 will overcome that problem.:D
  24. 48plysled
    48plysled
    We all know now is not the time to rush. lol But the suspense is killing us all eric. Your work has been top notch on this build. You should move to the states and lets start a shop buddy. :D Could use another set of hands in fabrication. All things aside though the car is seriously turning out awesome buddy.
  25. ANDEREGG TRIBUTE
    ANDEREGG TRIBUTE
    from Bordertown
    Alright.....if one more of these 41 Mopar Coupe threads rears its lil head....I am gonna consider it some sort of sign!! I do believe I have a new obsession!
  26. 1959apache
    1959apache
    any updates on little stuff you are playing with Eric?
  27. farmer12
    farmer12
    I did use copper brake line I had laying around, but this was just to make sure it would clear all the obstacles. I will be using stainless brake line when the time comes to do the final installation.
  28. farmer12
    farmer12
    Thank you for the kind words sir. Starting a shop is certainly going to be one of my goals in the coming years. Unfortunately it probably won't be in the US, but somewhere closer to home.
    Nothing wrong with a new obsession! Another 40/41 build is always going to be welcomed. What are you waiting for?:D
  29. farmer12
    farmer12
    Well Scott, the progress has been close to nothing the last week or two due to a family holiday and my regular job. On top of that, a young lady decided to ram my daily driver while it was parked......so trying to sort that out too. But, I'll be working on the Plymouth again next week. That's a promise.
  30. farmer12
    farmer12
    We want color! We want color! Well, here's the first one. It is isn't much, but it's a start! Just received a call from my painter that he's finished the rear axle. If anything is inspiring, it has to be freshly painted parts.:D
