y block intake?Can aaaai install a late model holly 4bbl?
Discussion in 'The Hokey Ass Message Board' started by mikhett, Jul 24, 2013.
  1. mikhett
    mikhett
    from jackson nj
    I have a 4bbl intake for a y block i want to install on my 292 can i trash the teapot 4bbl and go with what i know Holley 4bbl 600 cfm> Is the teapot a good carb? Thanks Mike
  2. sunbeam
    sunbeam
    You will have to use an adapter or find a 1957 and up manifold.
  3. ParkinsonSpeed
    ParkinsonSpeed
    I'm looking at making a manifold because they are getting too expensive for me and a little hard to find for the Y-Blocks...
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    The teapot aka "Flaming toilet" can be a good Carb IF and mean IF you can find someone that knows how to restore one, there is a guy here that does:http://fordbarn.com/forum/forumdisplay.php?f=5 If you go the adapter route a Holley R1848 or Edelbrock 500 CFM works about best on a Y-Block.
  5. M_S
    M_S
    from SoCal
    Blue Thunder and John Mummert make a single 4bbl for the Y.
  6. OLD HEMI
    OLD HEMI
    I just gave my brother (synchro7 ) two 57 Y block 4bbl intakes this last weekend.
    Lee
  7. You can find an adaptor but the later '57 and up "B" intake is a better flowing manifold. As a mater of fact just go with a later 2 barrel, they work great.
  8. HEATHEN
    HEATHEN
    from SIDNEY, NY
    You don't have to run a teapot on the '55-'56 manifolds; Rochester, Carter, and Stromberg 4 bbl carbs from early Olds, Cadillac, Buick, and Chrysler V8s will bolt right on.
