Harmonic Balancer on 1960 chevy
Discussion in 'The Hokey Ass Message Board' started by dtwbcs, Jul 25, 2013.
  1. dtwbcs
    dtwbcs
    from Brenham,TX
    I have a 1960 Chevy w 235 original engine. Need to replace the harmonic balancer seal. HB wobbles& is leaking oil-not much; just enuff to piss me off:mad:. My HB was pressed on-NO bolt.
    1. How/What are the steps to remove HB:confused:
    2.Steps to reinstall
    3.3 days???
    Thanks in advance
  2. drofdar
    drofdar
    from Fresno Ca
    If the press-on damper is wobbling, you are soon to lose it, and perhaps experience some considerable damage in the engine compartment. You can borrow a puller, and installer from O'Reillys, or other auto parts stores. Since you are going to replace it, I recommend a bolt on style. You have to drill a hole into the end of the crank snout, and tap it for a 7/16 20 fine thread bolt. The bummer is that in order to do this, you will need to remove the radiator, and grill. Might consider some help, or an auto shop if you have not done this type of thing before. Good Luck!
  3. dtwbcs
    dtwbcs
    from Brenham,TX
    I ordered a "repair kit" from rockauto.Thinking that should fix it.(leaking seal).Or should I just order a new HB?Where would I buy from??
    Have a rt angle drill.That should help,right.?
    Havent done it b4 BUT AINT scared o it either....
  4. skinner784
    skinner784
  5. skinner784
    skinner784
  6. skinner784
    skinner784
    Posted using the Full Custom H.A.M.B. App!h m
    ..;jppxppevr.ee
    'V pppYr'8 pppp
  7. skinner784
    skinner784
    I
    Posted using the Full Custom H.A.M.B. Asp!n
    DL
  8. dirty old man
    dirty old man
    Please do us all a favor and stop posting till you learn how, OK?
    On a 235 6cyl, I wouldn't worry about drilling and tapping for a retainer bolt, as I doubt you're gonna run it at high rpms anyhow.
    That "repair kit" is most likely a new seal and gasket plus a thin metal sleeve you push on the nose of the balancer to give the seal a new surface not grooved by long use. Not gonna do a thing for your problem, which is that the bond of the rubber that is sandwiched between the inner steel or iron hub and the outer metal ring is giving up and about to let the ring slide off and tear up all sorts of stuff on it's way out.
    Here is a link to rebuilt balancers just in case you are unable to find a good used or new unit: http://hbrepair.com/harmonicbalancer_018.htm
    If you find a used one, check it closely as to the condition of the rubber, and also try to determine whether the timing marks are still in the right place.
    As stated earlier, you can borrow (with a refundable deposit) a puller/installer @ Auto Zone or Advance.
  9. dtwbcs
    dtwbcs
    from Brenham,TX
    Motor was dropped less than 6" onto ground.It was on a flat cart being pushed to truck;to take home;hit HB .It took the impact.I was hoping to be able to reuse the HB.It has less than 200miles on TOTAL rebuild.
  10. dtwbcs
    dtwbcs
    from Brenham,TX
    Where can i buy a new one.......................
  11. dtwbcs
    dtwbcs
    from Brenham,TX
    Ole Man;kinda agree its the rubber "messed"up;but wont know til its off
  12. dtwbcs
    dtwbcs
    from Brenham,TX
    THANKS Dave,
    Probable send mine to have it rebuilt
  13. dtwbcs
    dtwbcs
    from Brenham,TX
    Is there an oil seal behind the HB? Part#?
  14. Torkwrench
    Torkwrench
    One of the best things that you can do for your 1960 Chevy is to buy a "Factory Chevrolet" shop manual. It will show 99.999% of everything to fix a 1960 Chevy.
    You'll need a 1958 Chevy shop manual and a 1959 / 1960 supplement. Reprints are available and used ones can be bought pretty cheap on Ebay.
    They are well written, with very good illustrations. You'll be amazed at how simple a shop manual can be, compared to the ones for new cars.
  15. budd
    budd
    i'd be checking the crank to make sure it didn't get bent
  16. Rattle Trap
    Rattle Trap
    That was my first thought when I read that it had been dropped.
  17. Hotrodbuilderny
    Hotrodbuilderny
    Same here
  18. dtwbcs
    dtwbcs
    from Brenham,TX
    didn't appear to be. In the center of the HB it was smooth-no wobble to it. Think Dave hit it dead on. My guess is the rubber cratered inside.
    Will update in a week or so...when HB is returned
  19. Truckedup
    Truckedup
    I have one here you can have for the price of shipping. Probably about 13 bucks in a USPS flat rate box. It's 3/8 belt belt pulley,all good except a groove where the seal rides. A repair sleeve will fix it and they are the same as a Small Block Chevy....
    PM me if you want it.
  20. dtwbcs
    dtwbcs
    from Brenham,TX
    Truckedup--
    wished U would've spoke sooner; already sent mine 4 repair...thanx tho
  21. dtwbcs
    dtwbcs
    from Brenham,TX
    Mine is non-repairable...Where can I find a HB 4sale?
  22. budd
    budd
    knowing what other harmonic balancers fit would be a good start.
  23. dtwbcs
    dtwbcs
    from Brenham,TX
    Budd
    U R rite
    What OTHER HB will fit the 235??
    Having trouble finding what will fit
  24. dirty old man
    dirty old man
    Find somebody with an older Hollander Interchange Manual, maybe somebody that's been in salvage yard business a long time.
    Why couldn't yours be repaired?
  25. gearheadruss
    gearheadruss
    from Seattle
    after you pull off the harmonic balancer have somebody start the engine and look carfully at the crank to see if there is a wobble or to see if the crank did get bent. We just did a 327 that had a similar problem and with the harmonic balancer off and the engine running it didn't leak any oil out the front and we were lucky that the crank was straight. We used a dremmel with 3 circular disks and cut a new keyway and it fixed our problem. Finding TDC was a problem.
  26. Truckedup
    Truckedup
    235 damper fits on a 235-261 properly.There are several pulley sizes.. Others will press on like GMC 228-302, Chevy 230-292 and even a SBC... But things don't line up and or they need machining work.A 216 damper will fit ok but it's better to use the bigger 235 damper.
  27. dtwbcs
    dtwbcs
    from Brenham,TX
    Egg shaped is what I was told;cost too much fr maching correctly.
    SO I am now on the hunt,maybe......
