16 inch chevy steelies
Discussion in 'The Hokey Ass Message Board' started by mr37buick, Jul 24, 2013.
  1. mr37buick
    mr37buick
    from arkansas
    Hi everyone I have a question I have a 1937 Buick original front end well I did a front disc conversion and the rear end is from an 83 chevy Monte Carlo with rear disc conversion as well and I need to see where I can find 16 inch steelies please help
    thank you Jose
  2. historynw
    historynw
  3. mr37buick
    mr37buick
    from arkansas
    Really great i was wondering if I could just grind on the calipers some so it would clear the rim I have steelies on there now but they rub thank you alot for the info historynw
  4. mr37buick
    mr37buick
    from arkansas
    Historynw is there a general amount the can be grinded off from the calipers and still be safe
  5. flatheadpete
    flatheadpete
    from Burton, MI
    I used S10 spare saver wheels with bias ply Firestones on my T bucket. Cheap and easy to find....
  6. mr37buick
    mr37buick
    from arkansas
    Great idea flatheadpete if I can't grind my calipers im goimg to look into that thank you
  7. Hnstray
    Hnstray
    from Quincy, IL
    BIG difference in weight between a T bucket and a '37 Buick.........be sure the wheels are adequate for the tire width/size and loads imposed by the Buick. I realize the wheels are from an S-10, which is heavier than a T-Bucket, however, those space savers wheels are part of the "Temporary Use" spares.
    Just because something will "fit" doesn't mean it's suitable for the job requirements. Check into the loading limits of the wheels before putting them into full time use.
    Ray
  8. mr37buick
    mr37buick
    from arkansas
    Very true Hnstray I hear you
  9. Studebricker
    Studebricker
    from TX
    I was going to go with 17" rims on my car eventually. I have found that 16" tire choices seem to be fairly limited, so I would go 15s or 17s just based on greater tire selection.
  10. mr37buick
    mr37buick
    from arkansas
    Yeah but unfortunatly the style of hubcaps im trying to use only come in 15's
  11. mr37buick
    mr37buick
    from arkansas
    [​IMG] These are the hubcaps im trying to use on my 37
  12. scootrz1
    scootrz1
    from usa
    not 16 inch but when i put disc on my Bee I ground top of caliper and also inside of front wheels Before i mounted and balanced the tires . clears fine and did well over ten years ago
