Projects Morgans 51 chev sedan build up (Australia)
Discussion in 'The Hokey Ass Message Board' started by Morgan91, Oct 12, 2011.
  1. Morgan91
    Morgan91
    from Australia
    Got all my air gear from Glen at Air ride in Melbourne. The accuair valve blocks are awesome, I've used a couple of them on different cars and they are so easy and reliable.
  2. ausbuick
    ausbuick
    Cheers morgs.
    I think I will get mine from him also.
  3. Morgan91
    Morgan91
    from Australia
    Been slack with updating the thread but been getting heaps done.
    Tubs are primed and tacked in, both quarters are hammered to the shape they are sposed to be (thanks to my dad), I started in the rear floor sections tonight. Also been stuffing around trying to get all the front sheet metal to line up probably got 6 hours just in that so far haha.
  4. oldschool36
    oldschool36
    Excellent work, thanks for sharing
  5. Morgan91
    Morgan91
    from Australia
    Started on the rear firewall and got the sheets cut and bead rolled, and marked ready to fold, for the rest of the rear floor sections gonna go up the road to borrow an engineers folder tomorrow so hopefully have it all tacked in by the end of the weekend
  6. Outback
    Outback
    from NE Vic
    good to see progress happening!
  7. Morgan91
    Morgan91
    from Australia
    Got the other pieces folded today and fitted in, compressor mounts made, holes drilled where they had to go and got the pieces cleaned up and primed ready to weld in tomorrow
  8. Morgan91
    Morgan91
    from Australia
    Started welding the Floor sections in this weekend, got most of it done just need to finish off a few little bits then por15 the joins and Seam seal it then its time for sound deadening.
  9. Morgan91
    Morgan91
    from Australia
    So got the welding finished tonight and painted the joins and any other bare metal with POR 15.
  10. morac41
    morac41
    Hi ... Great progress.....(Dads are great)......Cheers Doug
  11. xwattsx
    xwattsx
    You little devil morgs, looking killer!
  12. Morgan91
    Morgan91
    from Australia
    Thanks wattsy, its getting there!
    Tonight's update, just got it all seam sealed up and did some little things on the list like brake line clamps and heat wrapped the exhaust .
  13. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
    This thing is coming along, enjoying your build thread and thanks for posting all that has been posted so far.
  14. Morgan91
    Morgan91
    from Australia
    Thanks for the feedback guys!
    Bit more progress, all the rear floor sections are finished and I put in The sound deadener today, painted the fuel tank and put that in, mounted the compressors, few other small bits and pieces still heaps to do before chopped tho.
  15. fat141
    fat141
    Hey Mogs, it's looking great. Come a long way since our encounter at Bright.
    Cheers and good luck young fella
    Rod
  16. Morgan91
    Morgan91
    from Australia
    Hey thanks Rod. Seeing your car is pretty much what started all this 2 door business haha.
  17. Morgan91
    Morgan91
    from Australia
    Progress is still happening, Bit more welding and shrinking and what not on the quarters. Compressors are all wired up, stripped the floor and firewall tonight and painted it with POR15.
  18. Eyeball
    Eyeball
    Great work! Keep the updates coming.
  19. Morgan91
    Morgan91
    from Australia
    Cheers boss, unfortunately I'm working away this weekend but updates will keep coming Monday night when I'm back to it!
  20. ausbuick
    ausbuick
    Good work bro
  21. Morgan91
    Morgan91
    from Australia
    Little update finally!
    After working away for 4 days I was having withdrawals from working on the chev, but when I got back to work today my EMS patch panels for my doors had arrived, so I was pretty happy with that! Started t******* the p***enger door ready to for the inner panel. Also just crossed another little thing of my list, the little rubber boot on the gear shifter, I used a universal boot for a CV joint.
  22. Muzz
    Muzz
    Good work, keep it going.
  23. Morgan91
    Morgan91
    from Australia
    Got Back at it tonight, few small things on the list like brake line mounts on the diff and earth straps ext made and installed. Nothing worthy of a picture. Some picture worthy progress should be coming tomorrow hopefully!
  24. Morgan91
    Morgan91
    from Australia
    So basically spent the whole day on it today and didn't get much done at all, tryed to make radiator hose to get around my engine mount. (Should of thought of that when I made the mounts) and think I was successful eventually, got called out a few times for work so didn't have a very productive day, hopefully tomorrow is a different story.
  25. Morgan91
    Morgan91
    from Australia
    Some proper progress today, got both inner patch panels on the doors cut in and tacked on, and started to patch some other parts of the door, might end up making a whole new skin for each door, see how I go.
  26. hughesy
    hughesy
    Always good to see some progress..
  27. ausbuick
    ausbuick
    I like the way you mark out the repair section Morgs..
    Cheers Darren
  28. Great project and in good taste.
  29. Morgan91
    Morgan91
    from Australia
    Cheers guys!
    Bit more progress tonight. Got some rust repair sections finished up and did a bit more of the sound deadening but ran out of it so still have the front floor pans and firewall to do. Also trying to figure out what to do for the inner quarter panel was going to make new sections but I think I might use the old door frames so that it looks like it could if been original and also might be able to use the window mechanism to have the back windows go up and down.
    Also gonna try to make my own door skins that go higher then the EMS ones. Still gonna use the EMS door inners
    Cut some sheet to size and marked the bottom fold just need to go up the road and borrow a folder so I can start marking them out ImageUploadedByH.A.M.B.1375099211.263243.jpg
  30. Morgan91
    Morgan91
    from Australia
    Progress from last night, got the inner door structures trimmed to fit in the hole, they look pretty good in there, might even be able to use the stock window mechanism to make the windows go up and down. Will sand blast and prime them tonight and hopefully have them all welded in by the weekend!
