brake light switch
Discussion in 'The Hokey Ass Message Board' started by olds34dude, Jul 27, 2013.
  1. olds34dude
    olds34dude
    from florida
    does the hydraulic brake light switch care what direction it aims, I mounted mine aiming at " 3 o'clock", as opposed to straight up, is there any reason it won't work this way? thanks
    D
  2. 325w
    325w
    Should be fine.
  3. 1971BB427
    1971BB427
    from Oregon
    Not directional.
  4. Hot Rod Chris
    Hot Rod Chris
    nope, it is non directional as it works off of pressure. You are good.
  5. olds34dude
    olds34dude
    from florida
    Thanks, that's what I thought and it nmakes it easier to access the screws,D
  6. HotRodHighley
    HotRodHighley
    from cincy, oh
    Mine's mounted at 3:00 and works fine.
  7. unkledaddy
    unkledaddy
    Those hydraulic brake light switches aren't wonderful. Step on the brake pedal and see at what point the brake lights actually come on...............you may be surprised to find that you are actually braking (slowing down) before that happens. A properly mounted and adjusted mechanical brake light switch will keep 'em off your ***. I left my hydraulic switch in place just as a back-up for the new mechanical one.
  8. jcapps
    jcapps
    from SoCal
    Non directional
