'34 Ford Coupe Quarter Bead Size?
Discussion in 'The Hokey Ass Message Board' started by cactus1, Sep 2, 2011.
  1. Can someone tell me what width the upper bead is on a '34 coupe quarter panel? I'm thinking 1-1/8" but would like to verify. I am also curious if it tapers as it drops to meet the lower bead?
    Thanks peeps!
  2. general gow
    general gow
    MODERATOR
    mike,
    where do you want me to measure it, and on the 3w or the 5w?
  3. Can you measure the 5w in a couple of places behind the door, 1/2 way, and at the merge of the wheel lip and quarter bead? Thanks man!
  4. Also, if anyone would be willing to trace their quarter panel to make a pattern and send it to me, I would pay you for your time/ materials/ postage. Thanks.
  5. general gow
    general gow
    MODERATOR
    i'll work on it tomorrow. pm me your number and maybe we can talk a little bit about what it is you need, specifically.
  6. BELLM
    BELLM
    My '34 5w, original quarters, halfway 1 1/16th", at merge 15/16ths". Hope this is correct, will see what others measure.
  7. Cool. Thanks BELLM.
  8. Survey Says...
  9. general gow
    general gow
    MODERATOR
    sorry mike. the weekend got away from me. headed out to a cookout at my moms, but i will take some more measurements tonight, and we'll talk about the patterns.
    mark
  10. No apologies necessary Mark! Enjoy the cookout and get back to me when you can. Thanks brutha!
  11. Sent from my iPhone using TJJ sucka!
  12. Look out Pat Pryor...
  13. RadRandy
    RadRandy
    from Kansas
    Could you post some pics of your bead roller and where you bought the die you are using? I am in the market to buy a wide bead roller setup and like the width you are using. Thanks!
    Randy
  14. Hey man. My bead roller is a modified HF unit here...http://www.jalopyjournal.com/forum/showthread.php?t=666579
    I had the bead dies made by a friend of mine who is a machinist. I didn't really look around to see if that size bead is already made commercially though?
    Hope this helps.
  15. RadRandy
    RadRandy
    from Kansas
    Sweet, I missed that build. Nice work.
    Thanks!
  16. Thanks man! Good luck with your project!
