8.8 Rear end swap
Discussion in 'The Hokey Ass Message Board' started by sine-bar, Jul 29, 2013.
  1. sine-bar
    sine-bar
    from Iowa
    I've got a 41 Plymouth truck, I just got a 8.8 Explorer rear end that has a sway bar on it, would there be any noticeable difference using the sway bar over the stock setup
    Brent
  2. Seabeebu3
    Seabeebu3
    I'm looking at the same setup for my 1946. What ratio did you go with?
  3. nickleone
    nickleone
    Most cars/trucks that have REAR sway bars also have a FRONT sway bar.
    With no bar in front you can have the rear come around real quick in a tight high speed turn.
    Nick
  4. 38Chevy454
    38Chevy454
    To add to this. In general a front bar increases understeer, a rear bar increases oversteer. You should always use a front bar (and typically bigger size diam) if you use a rear bar.
  5. sine-bar
    sine-bar
    from Iowa
    I'm going with 3.73, t-5 transmission so I can have the overdrive and I have a 315 Hemi that I'm planning on using.
  6. Jalopy Joker
    Jalopy Joker
    so, post a pics of your '41 including rearend - already mounted? changed spring pads? custom drive shaft?
