**Horray for the star spangled Banger** July 2013 Banger meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Jul 1, 2013.
  1. brett4christ
    brett4christ
    Snyders can regrind the cams to a more road-friendly profile for $59+exchange. I've got to get the cam out of my old engine to see if the mains and lobes are above minimum diameter....
  2. with the limited amount of info that i know about windfields is that the s or the sr really only describes the accelerator pump thingie on the front
    they look to be B or BB size carbs
    nice work on getting the setup
    tk
  3. colinsmithson
    colinsmithson
    G98T engine were German low compression engines improved B Model for farm and industrial use also the Ford Ruhr Trucks until 1954
    G28T were the Same engine High compression better camshaft for cars and Trucks (Ruhr)
    The Russian Gaz engine was copy of A model
  4. easyrider47
    easyrider47
    Sorry guys, kinda off the go-fast spectrum, but...I have a Model A running ch***is that I would like to make a speedster type beater out of. I want to use the seat similar to the ones rootlieb sells but someone suggested I use 55 gallon barrels to make my own. I like that idea but does anyone have one of those they could make a cardboard template of the shape they could send me so I have a pattern to use on the barrels. Thanks
  5. brett4christ
    brett4christ
    Unless you're a 55-galon sized guy, a 55-gallon drum might be a little big. Look for the 35-40-gallon size.....
  6. SJR
    SJR
    55 barrels are about 24" dia x 36" tall
  7. As mentioned earlier, I do not have knowledge of G98T-heads, as I have only had G38T's and seen G28T's.
    Whether the KF stands for Köln Ford, I also do not know, as I have only seen the logo casted into the head (and clutch housing).
    Russian Gaz build model A's on licence, and these engines I know almost nothing about. But the Gaz "AA" are made in several a very fine model kits!
    But your link, Majo, seems to be rather resourceful. Hope you find, what you need of info! :)
  8. skryla
    skryla
    from Brick, NJ
    Anyone know about a Winfield Vibration Neutralizer. There was one on EBay and I bought it on a whim for my B engine?
    Experience, thoughts or comments are welcome.
  9. BCCHOPIT
    BCCHOPIT
    I was looking at it on EBay
    I didn't have time to look and see what they went for new so I never bid.
  10. Crazydaddyo
    Crazydaddyo
    My info is not from personal experience. The problems I've heard about these is that they vibrate loose. If you use it, make sure you check the tightness of all of the bolts on a regular basis.
  11. I was told that there could be a minor clearance problem that would require some grinding to clear spring "U" bolts, seems it was only 28 29. Not sure as it was a few years back when the company first started reproducing them. Use Loc***e on the bolt!
    How many of you knew Gene Scott ?
  12. skryla
    skryla
    from Brick, NJ
    Thanks guys. Does anybody know if this thing really works?
  13. Wardog
    Wardog
    I'm not realy a lot of help. But I can tell you it looks alot like this standard neutralizer on my club brother's Lincoln Zephyr V12.
  14. BCCHOPIT
    BCCHOPIT
    Send it to me and I will give you a full report...
  15. skryla
    skryla
    from Brick, NJ
    Anybody recognize this workmanship. I was told it was about 30 or 40 years old
  16. BCCHOPIT
    BCCHOPIT
    I would hate to be the one to keep that flat...
  17. Creative!
  18. skryla
    skryla
    from Brick, NJ
    I ran a straightedge on the manifold side - STRAIGHT
    Someone really took their time.
  19. ok having some problems
    order some stuff from REDS
    no responce for a week
    called 3 times
    finaly get a guy and ask about the statius of my order (header side plate and head studs)
    oh the web site is wrong
    header is 2 weeks out
    side plate is 2 weeks out
    i canceled my order.....
    i am not usually an instant coffee kind of guy, but i know how it goes when 2 weeks turns into 3 ect
    so now where do i get some head studs (winfield head install)
    i dont really care about the aluminum side plate (it was kind of an inpulse buy)
    header would be cool also, but i am not sure i want a cast iron header like snyder sells or Charlie yapps
    is there a prefered/alliance vender that sells banger hop up stuff
    or any of you guys have anything laying around
    tk
  20. brett4christ
    brett4christ
    Intakes/headers....hit up BCCHOPIT here on the HAMB. Someone has (or had) side covers in the cl***ifieds as well. Head studs....Snyders, Macs, Sacramento Vintage.....take your pick!
  21. SJR
    SJR
    give me some time Ill be building headers, if there is enough interest Ill cast some side covers and intakes, header first
  22. Crazydaddyo
    Crazydaddyo
  23. Wardog
    Wardog
  24. Wardog
    Wardog
    Just trying to sort the app out guys, With a photo of my coupe.
  25. Crazydaddyo
    Crazydaddyo
    You are 7 months late.
  26. Wardog
    Wardog
    I thought no one would catch me:)
