32 ford hood
Discussion in 'The Hokey Ass Message Board' started by kusdomh, Jul 31, 2013.
  1. kusdomh
    kusdomh
    can anyone tell me the measurement from cowl to radiator shell? thanks
  2. Pewsplace
    Pewsplace
    All 32 stock Fords are 32 inches from cowl to shell.
  3. Mine is 32 5/16" that is from cowl to grill
  4. HOTRODPRIMER
    HOTRODPRIMER
    A stock 1932 Ford hood,20 or 25 louver is 32 inches. HRP
  5. Rootleib says 32"
  6. 383deuce
    383deuce
    They are corect 32"....But mount your shell first and then set the body and hood to fit. Makes it a lot simpler to make it all work.
  7. gearheadbill
    gearheadbill
    Just remember that there are no rules; only guidelines. Make it look right no matter what the dimensions end up being.
  8. Fogger
    Fogger
    I've got three '32 Fords and the way I've fitted the hood and grill shell is to the body not the other way around. The radiator can be shimmed up on the front cross member to adjust the hood gap at the cowl and grill shell. Also the belt line can be adjusted by raising the rear of the hood top. Some aftermarket hood tops are too wide and the belt line is low at the cowl. Many times the hood top has to be modified so the reveal lines up. It can be easy or not, good luck!
  9. Deuce Daddy Don
    Deuce Daddy Don
    Mine measures 32 1/2 from Henry body & shell.
