dd or smooth shaft
Discussion in 'The Hokey Ass Message Board' started by tobyflh, Jul 31, 2013.
  1. tobyflh
    tobyflh
    from Peru il
    Getting ready to set up my steering and was wondering do I go with dd or smooth shaft. I have a chance to buy a good brand of smooth joints and wanted to know if one was better choice. It's going in my international bobber truck that I'm building. It is a light weight truck if that helps. Thanks for any help.
  2. Harvey29
    Harvey29
    from kansas
    I wish I would have used DD just because its a little easier to work with, but either one is fine
  3. dreracecar
    dreracecar
    from so-cal
    Smooth/round you are asking the setscrews to handle all the load
    DD the shaft is handleing the load and the screws are just holding it in place
  4. yes.....DD is the way to go
  5. Cruisinthe34
    Cruisinthe34
    I like DD because its easy to work with. I usually detent each end of the shaft where the set screw contacts.
  6. rrthiv
    rrthiv
    from S.E.Ohio
    Another vote for dd...
  7. tobyflh
    tobyflh
    from Peru il
    These are the answers I thought I would get but I figured I better ask just in case.
  8. Fenders
    Fenders
    Not if you weld it on.
  9. alchemy
    alchemy
    Use the DD or splined. Don't use smooth shafted that needs welding or pins. So much easier to remove/replace when you can just remove a couple set screws and out it comes.
  10. the-rodster
    the-rodster
    It's just like breast sizes, Double D is the way to go.
    Rich
  11. HOTRODPRIMER
    HOTRODPRIMER
    Funny,but true! HRP
  12. readhead
    readhead
    I mock it up with 3/4 wood dowels and sand the flat spots on the ends to match the DD. you can use DD joints on round material. You just have to sand or machine the flats.
  13. jazz1
    jazz1
    I used round and welded the joints,,,I know...not such a great idea but i did not want to depend on a 1/4" bolt or set screw for my steering...next time DD
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    I don't trust set screws on either so I drill one all the way through and pin it with a 1/4 inch grade 8 bolt. Might not be the way some do it, but it works for me.
    Don
  15. Pooch
    Pooch
    from Oklahoma
    DD is the only way to go
  16. nunattax
    nunattax
    Splined shaft is the way to go.check out the borguson site
  17. 65standard
    65standard
    As far as I know the round u-joints are weld type. Nothing wrong with them, just not removable.
  18. We used the DD in our roadster build...
  19. ROADSTER1927
    ROADSTER1927
    As long as you are making it, use DD so it can collapse in a collision ! Gary
  20. Dutch54
    Dutch54
    Borgeson recomends smooth for racing only. Something about vibraton cracks. Of course I read that after welding mine up. Next time I'm going DD.
  21. Weasel
    Weasel
    You should never weld steering joints - it weakens the joint by up to 30%.
    Here's what Borgeson has to say on the subject:
  22. tedley
    tedley
    from canada
    I didn't drill through my DD shaft. After i put the set screw in it leaves a mark. Take the coupler off and drill only enough to counter sink the set screw. Then used blue lock tight in the set screw and lock nut.
