41 plymouth / or 55 dodge? what do you think?
Discussion in 'The Hokey Ass Message Board' started by moparkevin, Oct 23, 2010.
  1. 73RR
    73RR
    That '55 is nice! Depending on what, exactly, is the issue with the engine, it may or may not require a full rebuild. Hard to tell until you get it home and can do a complete inventory of the parts pile.
    Is the engine out of the car? or just the top end? How long has it sat in the current state?
    Lots of questions, naturally, but it sure looks like something to have and if it was a thousand miles closer I'd have my trailer hooked up...
  2. moparkevin
    moparkevin
    The 55 motor is out because he had it bored our .125.. wow! right.. and has been in parts ever since. Thats all I know at the moment.
  3. Dynaflash_8
    Dynaflash_8
    from Auburn WA
    Go 41. I had a 55 i couldnt give away for $600. No rust, og paint, no motor
  4. TMunster
    TMunster
    from Las Vegas
    im thinking the 41
  5. George
    George
    Have it sonic checked, may still be usable.
  6. el Scotto
    el Scotto
    from Tracy, CA
  7. 40's mopar wins. Just my opinion.:)
  8. RodStRace
    RodStRace
    Buy the 55 and put it on a S-10 ch***is with a worn but painted 305 SBC!:D
    Just kidding!
    What are your plans, budget and skill level?
    The 55 could be put back together and driven, if that engine is going to be a money pit another can be found.
    That would be the cheapest and easiest.
    If you want a hot rod, building the red ram and adding stuff like multi carbs, cam and compression can add up fast. Then you have to deal with the trans, rear and brakes.
    More down time, searching, building and money.
    The 41 can be built with a donor vehicle or parts collected.
    Probably the most expensive, since you'd want to do a full drivetrain, wiring, brakes.
  9. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    41 Sedan, 2 doors are better than 4
  10. moparkevin
    moparkevin
    well I talked to the guy yesterday... AND NOW IT'S GONE!!!! wtf that is the 3 55 ply/do I have lost by a day... aaaaaaaaarrrrrrrrrrrrgggggggghhhhhhhhhh
  11. 57dodge
    57dodge
    Probally didnt help with you posting the link to the Ad on here.
    Just sayin.........
  12. VonKool13
    VonKool13
  13. moparkevin
    moparkevin
    I wonder if someone did see it on here.. guess I find out when I see it this spring.......look out.
  14. ezrods
    ezrods
    I have a 1940 and a 1955 (both 4 door Plymouths). The 40 turns heads and gets alot of waves, hollars, and thumbs up. But the 55 handles much better on the road. Also, suicide doors are cool, but regular 4 doors are not soo hot.
  15. cowboy.3d
    cowboy.3d
    from Austin TX
    The '41 Nuff said.
  16. Rusty O'Toole
    Rusty O'Toole
    This is odd but if the 55 has a 6 cylinder and manual trans the 2 cars are practically the same mechanically. They were still using the same old flathead six, king pin front suspension, left hand threads on the wheels, tapered rear axles, they even both had 6V + ground electrical systems.
    The 55 was faster, nicer to drive and more at home on today's roads. But there was not a hell of a lot of difference.
    Either would be good, very much a matter of choice.
    Re: losing all the deals. I suppose if you don't have a mind of your own you have to come here and borrow somebody else's. But it does waste time.
  17. harpo1313
    harpo1313
    from wareham,ma
    i wonder what he choose,hes had three years to decide
