MEL 430 Super Marauder Question
Discussion in 'The Hokey Ass Message Board' started by rld14, Apr 28, 2011.
  1. rld14
    rld14
    Without boring you guys to death, my Uncle was telling me about a 58 Mercury that he used to see on the roads back in the mid 60s, he said it had a "Super Marauder" Lincoln engine in it and that it was one of the faster cars around. So I figure we're talking about an MEL 430.
    He remembers that the guy bought it cheap around 64 or so off a used car lot, dropped a motor out of a wrecked 59 or so Lincoln in it and ordered this setup from the dealer, supposedly it was a 400hp setup.
    I have been searching the board and can't find much unless I'm doing something wrong.
    My Uncle said he remembered that it involved a tri-power or dual quad setup and was otherwise a relatively stock engine.
    Anyone know more about this? A huge *** Black Continental sedan with 400hp might be fun to play with :D
  2. slickhale
    slickhale
    from Phoenix
    the super marauder was a mercury only option. it had a cast iron tri-power manifold, google search MEL, there is a pretty good MEL only website.
  3. FrozenMerc
    FrozenMerc
    The 430 was used from 1958 to 65 in Lincoln Continentals, '58 to '60 Mercury's, and '59 and '60 T-Birds. I believe the tri-power 400 Hp Super Marauder was a '58 Mercury only option. By '59 it was derated to 375 hp. The 430 used in Lincolns was rated around 345 Hp and had a single 4 barrel. The torque of the 430 is were it earned its reputation. Most were rated at 475 ft-lbs.
  4. There is a Lincoln version of that air cleaner ***embly but it does not have the script on it.
  5. petemonster
    petemonster
    from Minnesota
    I have seen that at a swap meet all pitted up.The guy wanted $3500 for the complete setup.
  6. oldestman
    oldestman
    Resurrecting a year old thread to add some archival info for future reference. Super Marauder was a one year only option on 1958 Merc's on the 430 MEL engine only and was available in all models. It may not have been mentioned in any dealer brochures. Contrary to what was stated above, the manifold is aluminum, not cast iron. It was the first use of Holley 2300 2 bbl's on a tri-power set up. It was the first production Detroit iron to hit 400 HP and remained the HP king of the 1950's. The fuel injected 1958 Chrysler 300D's "only" had 390 HP. The manifolds were cast by Moon Equipment according to Wikipedia and I will try to verify that over the next couple of weeks. The secondaries ran vacuum pots similar to early Corvette tri powers. With the exception of the Moon information, all these facts have been verified by me in order to post an auction I currently have on eBay. BTW, that's not a plug because I don't think there's going to be an army on the HAMB ready to buy MEL parts. Here's a few pictures. Notice the similarities and dissimilarities to an FE manifold. The modification to run 2 bbl Rochester 2G's was done by a previous owner. From the factory they were only drilled for 2300's.
      159.7 KB
      142.1 KB
      138.8 KB
      140.3 KB
  7. MoparFoMoPowar
    MoparFoMoPowar
    from Kentucky
    Is there any difference in a mercury 430 super marauder and a stock lincoln 430 MEI besides the mercury has tripower and the lincoln has a four barrel?
  8. rld14
    rld14
    Nope.
    Please post an intro per board rules..
  9. sbakar
    sbakar
    The automatic transmissions were beefed up on factory-built Mercury Super Marauders (i.e. true J-code cars). Early on, there were plans to run a different cam in the Super Marauder but that was later nixed. The factory never officially built Lincoln Super Marauders even though a similar J-code program was rumored to be in the works, but tripower kits were nonetheless available from the dealer for both Mercury and Lincoln. The two kits differed slightly but not in performance: the air breathers were different and the Merc application used a vacuum cut-out switch on the starter because of the push****on transmission (prevented accidental starter engagement when the engine was running). The Linc did not use a push****on ******. The stock Merc 430 also used ramhorn exhaust manifolds whereas the Linc used logs and the Linc was rated slightly higher than the Merc (375HP vs. 360HP if my recollection is correct) although some have argued that was an advertizing gimmick perpetrated by Lincoln. It's my belief that the dealer tripower kits were made available to liquidate pre-production inventory after the super marauder program was cancelled.
  10. FOURTWOSEVEN
    FOURTWOSEVEN
    Just a quick note regarding the MEL engine...I am currently building two 462 Lincoln engines...one will have an offset ground stock crank, about 510ci, Harland Sharp rocker setup, Slover's heads, Diamond pistons, Slover's 460 manifold adapters to run a tunnel ram. If anyone knows where i could get a roller cam blank, please let me know. BTW, I am also working on using a 385 series (429-460) crank in a MEL 462 block...hoping for 550ci+ if it all works. If anyone has a pair of the big port big valve 1958 MEL heads, would be interested in those as well. Thanks, SJP
  11. Normbc9
    Normbc9
    San Diego Police Department had a fleet of these special order cars as "Pursuit Freeway Flyers." Their domain was Hwy 101, Hwy 395 and Hwy 80 (Mission Valley Road) and their history was one that influenced the California Highway patrol to order some also. One of those City PD cars exists and is restored in an Auto Museum in San Diego.
    Normbc9
  12. jambottle
    jambottle
    where did the 58-60 Edsel fit in. Big heads?
  13. Looks like the underhood of Brian Stefina's 58 Merc 2 door post sedan. A truly beautiful car.
  14. Chris430
    Chris430
    Waking up an old post here:
    The Edsel has E475 on the valve covers which is the rated torque. It was a 410 cubic inch. 3.7" stroke like the 430 but had a 4.2" bore.
  15. MOONRNR
    MOONRNR
  16. MOONRNR
    MOONRNR
    - CONTINUED -
    Just Gary, UNSHINED 2 and loudbang like this.
  17. Chris430
    Chris430
    That is all I need to wake up the old F-250. Dropped a 65 430 with a 59 intake. The low end torque is nice.
  18. MOONRNR
    MOONRNR
    It was hell of an engine series. The 385 family (460) replaced it.
  19. Dave G in Gansevoort
    from Upstate NY
    Just saw this and it made me curious about the biggest engine Mercury wagons would have been equipped with in 1963. Dad had a Mercury wagon that had whatever was required to pull a trailer back then. I was only 9 years old but I do remember that it would really haul the mail...
  20. MOONRNR
    MOONRNR
    MERCURY went with the FE in 1961.
  21. FrozenMerc
    FrozenMerc
    In the later half of 1963 you could - in theory - order a 1963 Mercury wagon with a 427 FE Top-Oiler. I am not sure if anyone ever actually checked those specific boxes, but it was a possibility.
    Otherwise, the 406 FE was available as well, in early 1963. Supposedly, 176 Full size Merc's were built in 1963 with either the 406 or 427. How many ended up in wagons, is sadly unknown.
    The vast majority of wagons had 2 bbl 352's and 4bbl 390's. The 300 hp 390 was quite capable of pulling a small neighborhood around, as long as you could afford the gas.
    Dave G in Gansevoort likes this.
