  1. manjusri
    manjusri
    from US
    like this?
    I tried lowering it, too.
  2. xderelict
    xderelict
  3. MoparJoel
    MoparJoel
    Earlier this year sevenevez photoshopped some blue flames on my 57 Dodge, Ive kinda been wondering about some metallic Copper flames instead of the blue, the truck was copper when i got it and I liked it, named her Penny even but now the name does not fit. Could some one hook me up with a color change please?
  4. Rot 'n Kustom
    Rot 'n Kustom
    Quick color flip:
    57Dodge00 by DaveTartaglia, on Flickr
  5. hd1084
    hd1084
    Thank you very much. I'm sure this is what it will be. Great job and thanks again.
  6. OahuEli
    OahuEli
    from Hawaii
    Hey xderelict, I tried to scale your concept to a real 52 Chevy 4 door. It didn't work out well so I used a two door. Your idea seems to follow an early '50s era roadster concept and thats what I put together. Hope this helps. Eli
  7. nitrobrother
    nitrobrother
    OahuEli, you beat me to it! I was also working on a longer door version. Nice job!
    xderelict: Now build it! :)
  8. hd1084
    hd1084
    I just painted my fire wall white and would like to see what it would look like with white steelies, trim rings and moons, & black wall tires.
    Sorry for being such a pain but this is a great way to see what things will look like before you proceed with the final look. Thanks for all your great work. Really do appricate it.
  9. OahuEli
    OahuEli
    from Hawaii
    Thanks nitro, I was pretty happy with how it came out, but already see a couple of things I could have done differently. Go ahead and post your version when you're done with it. Its always interesting to see different peoples' perspectives on an idea.
    xderelict, I was thinking while working on your concept that this would be a real cool car to build. It appeared that you had sectioned the area above the beltline so thats what I did. Maybe I'll go back and section a little through the middle of the door too. That might give it more of a roadster feel.
  10. Tony Ray
    Tony Ray
    was wondering if anyone could hook me up with this paint scheme but instead of the white and green make it white and blue on my truck?
    Thanks in advance..
    and heres my truck..
  11. Flop
    Flop
    i forgot i even posted this !! thanks again ron !!!! looks great
  12. Pat Pryor
    Pat Pryor
    Can someone photoshop this into a black and white sketch? I've seen people do it. I just don't know what it's called.
  13. Rot 'n Kustom
    Rot 'n Kustom
    Here's one way to do it:
    Model A line 03 by DaveTartaglia, on Flickr
  14. kcbeardclub
    kcbeardclub
    from KCMO
    Hello All, I am trying to convince the wifey that my ride would look pretty sweet as a maroon tail dragger, I guess she's not as creative as I am because she seems to disagree with me, anyone want to give it a shot for me??. It would be mega appreciated.
      22.8 KB
      12.6 KB
  15. olympic2
    olympic2
    Here's another
  16. Pat Pryor
    Pat Pryor
    Thanks guys! Both are perfect, I really appreciate it!
  17. Ruben Duran
    Ruben Duran
    Had some time to do a few quick changes for ya......maybe others can offer up more options if they have time.
    Chrome reverse....
    Chrome reverse w/ drop
    Astros w/ drop
  18. Rot 'n Kustom
    Rot 'n Kustom
    Caddy wire wheel covers, medium whitewalls. Dropped a few inches with shaved handles and trim. I also closed the rear wheel opening so the open space behind the tire was not so wide.
    61Olds02 by DaveTartaglia, on Flickr
  19. hd1084
    hd1084
    bump !!
  20. flynbrian48
    flynbrian48
    So, I fired up the '59 T'Bird and actually drove it outside to begin to get it ready for paint. As I stood back and looked at it, it occurred to me that the headlights look "droopy" in the fenders, as they slant off level to the outside. I'm not sure I like that.
    I wondered if they might look better with the inside dropped about 3/4 of an inch, which means cutting the lip of the fender/valance panel between them and bumper, and making a little filler, so they set level with the ground. The effect I want is a little more sinister, or scowling, look, rather like the new Challenger or Camaro (NO, I don't want to use those lights, just the heavy lidded look they have).
    So, could someone whip up a little photoshop magic so I can see this before I start cutting sheet metal up?
    Thanks!
  21. kcbeardclub
    kcbeardclub
    from KCMO
    Anyone? Again, I would really appreciate the help before I get to stripping the body.
      22.8 KB
      12.6 KB
      11.5 KB
      97.3 KB
  22. Rot 'n Kustom
    Rot 'n Kustom
    Try this on for size:
    TBirdEyes01 by DaveTartaglia, on Flickr
  23. Ruben Duran
    Ruben Duran
    Pretty much did the same as Rot 'n Kustom, just dropped the inner light further.....
  24. Ruben Duran
    Ruben Duran
    Can you post a bigger pic of the profile (side) view?
  25. flynbrian48
    flynbrian48
    That's it, that's what I'm talk'n about! Thanks guys, both versions are a huge improvement over the sleepy look the original has. Now, I can start cutting...
    Brian
  26. rockabilly-medic
    rockabilly-medic
    Can you guys work your magic on my 54 Royal? Looking to go white with a flaked dark green top. Skirts and black steelies with the wide whites. Biggest thing is I want to see what it looks with a single spear running down the side. Don't know where to start it or stop it, atop the front fender well opening,? behind the front fender well opening running it low, starting at the door???,.. so many options... thanks in advance...
  27. James D
    James D
    Just a thought for the grille, if you fancied something a little different.
  28. guido`s 40
    guido`s 40
    from nebraska
    wanting to put some different wheels on the truck and am considering a 10 inch wide five window on the rear and a four inch five spoke on the front but not sure if polished or grey centers would look best. Any help would be appreciated
  29. flynbrian48
    flynbrian48
    Hmmm. I sort of like the wide, jet intake, look it has now. Interesting thought though. Looking at the front with the headlights fixed, what it really needs is to lose the rectangular park lamps. Round ones, about 3" diameter, recessed an inch or so into the bumper?
  30. James D
    James D
    Are painting the bumper again, or getting it replated?
