flathead v/8 questions??
Discussion in 'The Hokey Ass Message Board' started by furyfan, Aug 3, 2013.
  1. furyfan
    furyfan
    from MA
    I found this photo on the Vintage Shots threat. I am wondering what year(s) this engine was used and also the piece that has the arrow pointing to it; what is that for? I notice that the motor mount bracket is separate from the water pumps on this engine. Thanks for any info.
    John
  2. 296 V8
    296 V8
    from Nor~Cal
    Id say that’s a prototype for the upcoming 32 … note were the starter is - the exhaust ports - water manifold -..................................................
  3. cmyhtrod
    cmyhtrod
    from ct
    I think the arrow is pointing to a vacuum clutch arrangement. Lots of cars used them in the early 30's
  4. SMOG_GUY
    SMOG_GUY
    from Dinuba
    Google what the pic says. It's a prototype or model. Very unusual.
  5. furyfan
    furyfan
    from MA
    Thanks for the quick responses.
    John
  6. Fortyfordguy
    Fortyfordguy
    Motor appears to be a 1932 version.....the tall coil, the 2 blade fan, trans rear mount is the 1932 only style. The servo linkage does appear to operate the clutch release shaft from the RH side. Odd location for the starter would have had to cause the trans cover to be enlarged. Definitely looks like a prototype of some kind.
  7. 40FordGuy
    40FordGuy
    Definitely unusual.....The exhaust manifolds are an interesting piece. How was that vacuum clutch servo set up ?
    4TTRUK
  8. Those exhaust manifolds look odd but they would sure help it to stay cooler rather than having the exhaust ports run through the water jackets. Maybe Henry should have kept them on the production engines
  9. rat pup
    rat pup
    from houston
    Proto-type according to a wise old man by the name of Higgby Jinkins,
