Tranny cooler hook up
Discussion in 'The Hokey Ass Message Board' started by dubie, Aug 4, 2013.
  1. dubie
    dubie
    All I have left to do on my 56 pickup is to hook the ****** cooler to the TH350 ******. The cooler is made by Hayden and sold under the Parts Master name. Does it matter which cooler line goes in which end of the cooler? I've always ran the lines in and out of the cooler side on the rad but the rad doesn't have that option
  2. mustang6147
    mustang6147
    from Kent, Ohio
    You can run them either way....
    If you run them to the cooler then the radiator then the ******, its a preheater setup, used by many tow vehicles in cold climates.
    If you run them to the radiator, then the cooler then the ******, its further cooling the fluid for warm climates.
    Argument becomes, If you run the lines to the radiator then cooler your adding more heat to the radiator.....Make sure your radiator has the capacity, or if overheating becomes an issue switch them until you get a bigger radiator....
    Ideally is to keep both components at the same temp... 180ish or so
  3. barett
    barett
    from Taylor TX
    I was about to say don't run through the radiator at all. Then I noticed where you are... I would imagine the above advice is ideal.
  4. George
    George
    From what he said his radiator doesn't have a cooler in it. Shouldn't matter, usually plumb it so the flow is top to bottom.
  5. dubie
    dubie
    This cooler mount sideways with the 2 hoses coming out the bottom. The lines will run direct to the cooler and by p*** the rad all together.
    We don't get a lot of hot weather up here so as long as I can keep all the temperatures in check, that's all I'm going to worry about.
  6. barett
    barett
    from Taylor TX
    I've never run a "heat exchanger" for a ******, in Tx it just flat doesn't work, over time coolant temps heat up ****** temps. But I have to think in the great white north it would come in handy...
  7. Gerry Moe
    Gerry Moe
    My choice would be to run the supply at the bottom and the return at the top. The reason is to keep the hot fluid in the coil longer, when it comes out it will be the coolest. This is minimal but more efficient, either way will work tho. Of course if your cooler has both lines out of one end it won't matter either way
  8. dubie
    dubie
    Anyone know what kind of pressure is in these lines?
  9. i believe somewhere around 35-50 lbs, do not use regular rubber fuel line....use transmission cooler line
  10. curtis73
    curtis73
    ^^^ agreed. I've never seen one above 60, but that was partly due to a clogged cooler. 35-45psi is normal.
  11. curtis73
    curtis73
    Agreed. I personally don't like cooler-only setups for actual DD working vehicles but they'll work fine on a weekend cruiser.
  12. HOTRODPRIMER
    HOTRODPRIMER
    The cooler doesn't care which way the fluid runs. HRP
