Where did you mount your battery?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 16, 2013.
  1. sidevalve8ba
    sidevalve8ba
    I mounted an Optima in this ammo can. The can is bolted to the floor and I hole-sawed hole thru the bottom of the can and the floor of the be for the cables. Works just fine. This ammo can is wider than most I've seen. The battery fits in there just right.
  2. rustang
    rustang
    I built a battery box and bolted it to the frame under the floorboards....
    Tom
  3. GassersGarage
    GassersGarage
    My '32 3 window, the battery was behind the seat. The '31 Coupe had the battery in the trunk. My '51 Ford G***er and '52 Chevy had the battery in the trunk. My '65 Bicayne, '63 Grand Prix and '49 Ford had the battery in the stock location.
  4. Canuck
    Canuck
    Mounted in the trunk.
    Set up for two type 51 batteries, one at each end of the gas tank. Couldn't find a box the right size so made replicas of 50 cal. boxes to fit
    Canuck
  5. 1971BB427
    1971BB427
    from Oregon
    In the trunk on my Austin g***er, and also on my Falcon g***er. The Austin's trunk is so small it was useless anyway. Falcon is so big I could still toss a couple bodies in there! ;)
  6. fleetside66
    fleetside66
    This is an old shot...I have since covered the two big ventilation holes with a louvered plate. That's my toolbox I bought for myself for X-mas back in '72.
  7. terrarodder
    terrarodder
    from EASTERN PA
    Under the right front fender with remote battery terminals lower right hand side of firewall.
  8. tedley
    tedley
    from canada
    What an idiot i am. For some reason i had gas tank in my pee brain. Battery is under p***enger floor pan.:eek:
  9. SimonSez
    SimonSez
    Ditto
  10. MoparJoel
    MoparJoel
    My 57 Dodge's is in the stock location under the floorboard. It has a lid with spring steel tabs that keep it in place and a rubber floor mat that can be lifted up to access the Stock master cylinder and battery. It also has side skirts now to hide the clutter.
    Old build pic photo ^
  11. junkyardjeff
    junkyardjeff
    Stock location on all my old rides.
  12. dsprint2000
    dsprint2000
    Under the floor of the p***enger seat in my 34 Ford PU.
    David
  13. Dan Hay
    Dan Hay
    Side question: Will a battery for a 40 Ford fit in the stock location with an SBC? (p***enger inner fender). I know, it looks ugly.
  14. papa's 39 koop
    papa's 39 koop
    Behind right front fender on frame
  15. el Scotto
    el Scotto
    from Tracy, CA
    Flipped on its side leaking acid on the p***enger side floorboard.
  16. stimpy
    stimpy
    still trying to figure out a location as the trunk is big but the back half frame will take away from it and the exhaust running under it might present a problem , but thinking of putting it back up front on the firewall as the engine compartment is monsterous . ( 50 Cheiftan )
  17. Inland empire hot rods
    from so cal
    Mine is under the 50 Buick dash, small Odyssey
  18. jazz1
    jazz1
    Since I installed a 700 R4 the transmission crossmember prevented me from placing battery in stock location under floor so I put battery in my tool box.
  19. elba
    elba
    37 Chevy, underneath the right front fender. It rode there for 30 years. Out of sight, never gave me a problem.
  20. bobd1976
    bobd1976
    from Illinois
    In my old trunk along with tools and cleaning supplies
  21. 409ina49
    409ina49
    from Ohio
    Stock location. Under the floor.
  22. HOTRODPRIMER
    HOTRODPRIMER
    Nice looking woodwork. HRP
