Projects My first and only deuce project!
Discussion in 'The Hokey Ass Message Board' started by 31pickemup, Aug 4, 2013.
  1. 31pickemup
    31pickemup
    Hey Gang
    Well last year I bought a 32 3-window locally that was in storage since the 70's. It was a typical 70's style build. It had a 1972 350 with tri-power, 4-speed, Chevy rear end. It also had a flat sheet metal floor, recessed firewall, filled in cowl vent, magnesium hurst disk brakes and original interior was totally gone and replaced with buckets and a wood dash. One plus it's an original body and it had a original frame under it. While it was a running car it wasn't for me. So it went under the knife. Here are some before pictures and then Ill post some new pictures with details on whats going on with the build.
  2. HOTRODPRIMER
    HOTRODPRIMER
    I like it,I'm sure you will make it right. HRP
  3. studematt
    studematt
    Unchopped and unfiled roof. I likey.
  4. big duece
    big duece
    from kansas
    I dig it, dont chop it!
  5. 31pickemup
    31pickemup
    Ok so now it's way different. Going to a more traditional route. Original frame was saved and had a 39 X-member installed. Will be powered by a 1959 Ford Y-block with a vintage 573 Eldebrock tri-power intake. Here is a list of what it will run when it's done.
    1940 banjo rear
    1940 radius rods
    1932 split bones
    4" original heavy beam
    1939 Lincoln brakes
    36-39 Ford wide five rims
    Original firewall re-installed
    Original dash, steering column and seat re-installed
    F1 steering
    volvobrynk likes this.
  6. 31pickemup
    31pickemup
    Here are the most recent
  7. shoebox50
    shoebox50
  8. 31pickemup
    31pickemup
    Yeah this one will be unchopped and unfilled. :)
  9. mikeallcars
    mikeallcars
    Nice ride brother keep up the good work /
  10. rileyrecords25
    rileyrecords25
  11. Al Consoli
    Al Consoli
  12. teejay99
    teejay99
    I like your changes ...especially the Y-block .
    T
  13. 31pickemup
    31pickemup
    Yeah that wasn't the easiest engine to put in it. Without cutting up the firewall you have to move the front crossmember up 2" and run a remote oil system as the steering goes right through it.
  14. skinnydude
    skinnydude
    Nice car to start with, but you made it even nicer . thanks
  15. Sphynx
    Sphynx
    from Central Fl
    And you put the cowl vent back... You good sir are a Saint in the Deuce world.
  16. brady1929
    brady1929
    Sweet hot rod
  17. turdytoo
    turdytoo
    Really a nice piece and I totally agree with your plans. Only thing wrong is your statement about only '32 project. '32 are very addicting and when you get this one done............
  18. tinmann
    tinmann
    Loving all the changes so far.
  19. Really like what you're doing. And love the choice of engine. Well worth all the effort.
  20. Kiwi 4d
    Kiwi 4d
    Love the uncut firewall. Can you still run a stock hood ? What gets in the way of the front crossmember needing it to be raised 2"?
    We have a different problem here being RHD the starter and F100 box will probably want to occupy the same space.
  21. timwhit
    timwhit
    Very wise choices 31. We're excited!!
  22. ct1932ford
    ct1932ford
    Doing some nice work!
  23. 31pickemup
    31pickemup
    Kiwi we moved the front crossmember forward 2" because the Y-block has a very large water pump design. Tha'ts the only way to do it if you want to run a Y-block and retain the factory firewall. If I want to run a original style hood I'll have to buy one that's 2" longer.
  24. Kiwi 4d
    Kiwi 4d
    ****** , I haven't used my tape measure yet but could have checked my 32 3w with hot flatty for reference . I have a mint stock hood for our 32 Pick up . So it seems unless I can shorten the water pump considerably we are out of luck running a Y block in a 32 pick up with stock firewall and hood. that's a shame as we have a hot 292 with triples just waiting for a home.
  25. hasty
    hasty
    Looking forward to see how this turns out
  26. harleycontracter
    harleycontracter
  27. wicarnut
    wicarnut
    What a find, You should have bought some lottery tickets that day you found such a treasure. Kool! to WAY KOOL! John
  28. Kiwi 4d
    Kiwi 4d
    We will have shakeys rails build us a replica 32 ch***is here in nz. He does an awesome deal and quality workmanship . But alas no vin number. He will build it to your specs with crossmember as you require .
  29. 31pickemup
    31pickemup
    More pictures! They aren't the best but they work
  30. Nice find and nice save! Great work...
    -Shiny
