Door lock removal
Discussion in 'The Hokey Ass Message Board' started by Yelpat, Aug 5, 2013.
  1. Yelpat
    Yelpat
    from Arkansas
    How do you remove outside door lock on a 39 ford pickup
  2. Normal Norman
    Normal Norman
    from Goshen IN.
    There should be a set screw in the door frame pointing at the lock cylinder. Hope this helps. Normal Norman
  3. derpr
    derpr
    set screw?
  4. Mr48chev
    I think Ford used the set screws up through 51 at least as I remember them from taking the locks out of my 51 Merc.
    Here is a thread off Ford Barn on the subject.
    http://www.fordbarn.com/forum/showthread.php?t=20473
    There should be a hole in the door frame that is even with the lock that you can slip a screwdriver or allen wrench in if memory serves right.
  5. Yelpat
    Yelpat
    from Arkansas
    Thanks for the I formation I'll try that. It sure had me
    Scratching my head
  6. Yelpat
    Yelpat
    from Arkansas
    Crazy keyboard. Information
  7. Deuce Lover
    Deuce Lover
    Small access hole inside near door edge.Careful,that set screw is a slotted head(if orig) and if frozen you risk breaking 1/2 the slot off.Then its a real pain to drill it out'.
  8. ironpile
    ironpile
    For reference only,my 48 had a spring clip that slide in a groove on the lock cyl.Access was thru the inside door panel. 39`s may be different
    Good luck:D
  9. fordor41
    fordor41
    My '41Ford has a set screw in the edge of the door, After getting it out I replaced it with an allen set with anti-seize.
