Dumb wheel bearing question. I'm kinda stuck!
Discussion in 'The Hokey Ass Message Board' started by evintho, Aug 5, 2013.
  1. evintho
    evintho
    F100 conversion to '37-'41 spindles. It's been awhile since I pulled the crusty '56 brakes apart. I've got the Speedway conversion kit. Looking at the back of the hub. In what order do the parts go in? Is it seal, cup, bearing or cup, bearing, seal?
    Also, which way does the seal go in? Does the solid side go in first or the two piece side? Please pardon my ignorance!
  2. seb fontana
    seb fontana
    from ct
    Cup, bearing, seal [two piece side in].. you are going to pack the bearings with grease, right?
  3. tedley
    tedley
    from canada
    Seal goes in the way you have in the pic. I put a little lube on the cup and seal so it presses in easier.
  4. evintho
    evintho
    Little confused on the seal installation.
    This side goes into the hub first
    [​IMG][/URL]
    or, this side.........................
    [​IMG][/URL]
  5. OldFord39
    OldFord39
    from Monroe, Wi
    Seal goes in as is shown in the second picture; The first picture you show indicates the seal to be upside down, the lip would go towards the bearing.
  6. Hotrodbuilderny
    Hotrodbuilderny
    They go in order from bottom to top in post 1 the bottom two (race and bearing) you have facing the correct way, the seal is upside down.
  7. Fordtudor37
    Fordtudor37
    Bearing race (cup), Bearing, Seal (two piece side in first). Use large socket or Bearing Race installer to install race in rotor squarely all the way, rub bearing grease on race, then pack bearing as much as you can (excess is okay), then seal (use large socket or correct size thick wall pipe to install squarely in rotor. Where is the Bearings slotted washer, nut and cotter pin ?
    The lower picture shows the correct side to be installed first because the design of the "45 degree inner area" of the rubber part of the "seal" allows it to set itself correctly against the shaft so that the wide part of the rubber keeps grease in and garbage (water, etc.) out.
  8. OldFord39
    OldFord39
    from Monroe, Wi
    This side goes into the hub first ( correct )
  9. DD COOPMAN
    DD COOPMAN
    Put the seal in so that you can still read the numbers on the rubber after install. DD
  10. evintho
    evintho
    Got it! Thanks guys!
    Yes, I'll pack the bearings and I have the slotted washer, nut and cotter pin!
  11. tedley
    tedley
    from canada
    Actualy, if you have never done this before, get a buddy that has and watch him. Once you see how it's done you'll know for next time. It's critical they are done right. No margin for error here.
  12. Mr48chev
    You will hear the tone of the hammer blow on the driver change when the race is fully seated in the hub.
    If you haven't packed wheel bearings before ask someone how to do it correctly as dabbing grease on the outside of the rollers doesn't do a lot of good.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    You do know that you have to grind a larger radius on the bearing right? Do the grinding BEFORE you pack the bearing. Actually use tape on the roller area to keep grit out of the bearing. Grind enough so the bearing seats all the way to spindle shoulder.
  14. tedley
    tedley
    from canada
    Say what?
  15. evintho
    evintho
    Part of the conversion to '37-'41 spindles
  16. Hotrodbuilderny
    Hotrodbuilderny
    That bearing looks like it might be done already,slide the bearing on the spindle and see if it slides all the way on.
  17. dirty old man
    dirty old man
    I'm still trying to understand why you want to install 37-41 spindles on a '56 F100.
  18. seb fontana
    seb fontana
    from ct
    No, its 56 f100 brakes onto 37/41 spindles..
  19. seb fontana
    seb fontana
    from ct
    Some bearings [cones] come with a small radius on the bore/face that shoulders against the spindle seal diameter, not letting it seat by hanging up on the spindle fillet radius, thus the grinding to clear the radius on the spindle...That said, I have never had to grind on the bearing as they all came with enough radius over the past 30 years..
  20. 325w
    325w
    I ground bearings on two different cars. It was must to fit correct.
  21. Hotrodbuilderny
    Hotrodbuilderny
    If you enlarge the picture of the bearing you can see it's done.
  22. Fenders
    Fenders
    I've done this before (30 years ago) with no problem - now doing another set I put the seal in flush -- and it contacted the inner part of the bearing, preventing that part from turning.
    Didn't seem right ... but on second thought the inner part seats against the spindle shoulder and doesn't turn anyway -- is that right? It is the hub, race and rollers that turn....
    30 years is a long time to remember something... Straighten me out here, fellas.
  23. pug man
    pug man
    from louisiana
    not sure what you are asking Fenders but I will try and help you out. You have your hub then you put the race in first making sure it is facing out so that the bearing will fit inside of it. After you have the race in grease up that bearing real good then put it in so it slides down inside the race. Then you put the seal on with a large socket that will fit on the shoulder of the seal and hammer it on lightly. Hope that helps....
  24. Fenders
    Fenders
    Right, Pug -- but the seal (as shown in the OP first post) contacts the inner part of the bearing, not permitting it to turn (and putting pressure on it as well)...
    I see you said lightly... my question is whether it matters that the seal contacts the bearing.
    This conversion seal is a full thickness seal -- I note that on the original F100 seal is "hollow" on the back, where it meets the bearing race so it cannot contact the bearing; I'd like to use that type of seal for the older spindle, if there is such a seal. (see photos)
  25. saltflats
    saltflats
    from Missouri
    You wont want the seal to contact the bearing it wont let it expan out when it goes on the spindle. And you are correct that the inner race does not turn.
  26. Fenders
    Fenders
    What I thought.... thanks.
    The stock F-100 "hollow" seal allows the bearing to float in the race until the bearing is held in place by contact with the spindle upon installation.
    Unfortunately the ID of the stock seal is too large (1.75") for the old spindles (1.5").
  27. saltflats
    saltflats
    from Missouri
    You need to see if there is room for the seal on the spindle if the seal is not installed all the way.
  28. Fenders
    Fenders
    saltflats, I think that's the solution. I'll check.
  29. garyf
    garyf
    Easy way to remember, The lip on any seal always faces the oil or grease
  30. Fenders
    Fenders
    UPDATE:
    OK I don't want the "solid" type of seal that comes with the Speedway set (this seal is marked A34032 but I could no reference to that). When pressed in flush to the hub it pressed against the bearing, pushing the rollers into the race. I know it won't do this in every installation, but it shouldn't do it at all.
    Looking at the original 1953 - 55 F-100 front seal, it is is the "hollow" type -- when driven in flush to the hub the edges will (may) contact the race, but nothing contacts the bearing. You can reach in and wobble the bearing. So I wanted a seal like that, but with a smaller shaft dimension (want 1.563 inches).
    Looking for this seal dimension in the Timken seal manual on page 38
    http://www.timken.com/en-us/products/Do***ents/Seal-Specification-Guide.pdf
    lists seal #473441 as having the correct dimensions to fit the 1955 F100 hub bore (2.756" a press fit into the F-100 2.75" bore).
    Also this seal is Timken style 470, which is the "hollow" style (with a spring wrap - nice). I ordered a couple, and they work perfectly.
    (National/Timken #450461 recommended in some articles also looks like it could contact the bearing, it is Timken style 450)
    In the photo below, left to right, are a stock 1955 F-100 seal, the Speedway seal, and the Timken #473441 seal that I ended up using.
