motor swap
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by kutty, Aug 4, 2013.
  1. kutty
    kutty
    from Wisconsin
    Hello all,
    I'm new to this so if I'm doing anything wrong please let me know.
    I have the to purchase a Chrysler Industrial 230 Engine out of a combine.
    Can I put it in My '49 Plym in place of the 218? If so, is it just an easy swap or is there a lot of other things that need to be done?
    Thanks,
    Kutty
  2. kutty
    kutty
    from Wisconsin
    Thanks,
    Kutty
  3. jfreakofkorn
    jfreakofkorn
    welcome to the board ....
    1st this is the intro section ( read the sticky )
    2nd, if you post this question in the main board, im sure you ll have some answers ..
    3rd , just need to post once ...
    once again, welcome =)
  4. Welcome...a combine engine in a '49 Plymouth? I'll have to Google that combine engine and see what the interest is (got a '49 Dodge). Interesting idea though.
    After a quick search, I found your on to something! Over at: http://olskoolrodz.com/forum/showthread.php?t=40495 there's a write up of this. May have to keep an eye out myself, keep us posted but move your progress to the main board and out of the introduction section.
  5. BettyBlue
    BettyBlue
    Not a swap motor for motor, there will be some fabrication. Block is longer, you will have to swap motor mounts and move radiator to start
  6. ct1932ford
    ct1932ford
    Welcome from CT!
    Welcome from CT!
  7. mart3406
    mart3406
    from Canada
    Yep..not a straight 'remove one and
    replace it with the other' job but not
    a complicated or difficult swap either.
    Ma Mopar even did this "swap",
    right at the factory even, on
    Canadian-built Plymouths of that
    era, all of which - unlike their
    otherwise mechanically identical
    U.S-built cousins - used the slightly
    longer Desoto-Dodge-Chrysler
    Industrial' block.
    Mart3406
  8. BettyBlue
    BettyBlue
    Yeah Marty, I knew that. Is fairly easy. But if you find a 230, it drops right in. The Chrysler/desoto is 2.5 inches longer for more work. Drop a hot cam in a 230, split mani, dual carbs, shave the head .70 and you got a hot motor for nothing. You can also bore it out if you want...
  9. BettyBlue
    BettyBlue
    And autocorrect Mart... Sorry
