Got a chevy 250 and I put a 2x1 set up on it. Offe intake with rochester singles. Looking for linkage help. Offe sent me a kit with the intake but I have no idea how it hooks up and I the directions dont show a 2x1 set up. I know there has to be a thread already on this, but I cant find it. Any help would be greatly appreciated. Pictures even more so. I have the stock linkage. dont know if I use it or not.
I am running dual 1 barrels but on a Fenton manifold on a Flat Head MoPar engine. I made stand offs to go under the head bolts that has arms and rods from the throttle to the carburetors. I made plates to go between the carburetor body and the manifold that have an ear that extends out then bends 90 degrees to support the rod with the arms that operate the ****erfly on the offy manifold for my 235 Chevy..
The linkage runs front to back between the carbs, but from the pedal, is has to move that linkage up and down. Chopped picture is pretty close to what ive got. Any chance of getting a close up?
I have a pair of WA1s and am using a Lokar pedal with a cable to the carb linkages. If you can see in the pic, it does what you need to do. It pulls up on the linkage. Dom
It's been a while since I had the car , no other pics. I flipped the bellcrank, it pulled down on the linkage. I think I tapped a hole in the manifold to mount a bracket for the throttle cable.
