What RPM's are acceptable at 70 MPH?
Discussion in 'The Hokey Ass Message Board' started by Louie T, Aug 8, 2013.
  1. Louie T
    Louie T
    I have a 454 (.030) in my 58 Caddy. It has an RV cam and a Mighty Demon 650 carb. The heads are stock. The ****** is a 700R4. I'm at 2100 RPM's at 70 MPH. Is that considered high for that set up? I want to take advantage of the monster torque motor and change the rear gearing so I'll be in the 1500-1700 RPM range at 70. My wheels are stock size and the rear end is stock. So what RPM's are you guys turning at 70?
  2. ThrottleJockey
    ThrottleJockey
    I think thats great.........a little low even.
  3. 61 chevy
    61 chevy
    unless you want to save more gas, I would leave it alone,
  4. I can't think of a reason to be lower than you are!
  5. Chevy Gasser
    Chevy Gasser
    In my '55 Chevy I've got 700r4, 3.08's, 235-60-15's and that's about what I turn.
  6. 1Bad67
    1Bad67
    Old rule of thumb for hot rod gearing is 20 mph per thousand RPM. At 70 most of my junk would be turning 3,500 RPM
  7. pitman
    pitman
    Maybe Hoop can locate a Volumetric Efficiency curve, as He comes up with this sort of data, my best guess is you are just entering your better efficiency range @ 2100.
  8. Bob K
    Bob K
    from Antigo Wi.
    The Tremec in my 62 Vette has me turning 1900 at 75 mph.
    B:)B
  9. Louie T
    Louie T
    Economy is sort of what I had in mind. I know it's a BB and my options are limited. I was thinking I want the motor to be purring along like it does at 60. I didn't think to investigate what RPM is the most "efficient".
  10. GregCon
    GregCon
    from Houston
    I personally limit RPM at 70MPH to 3000.
    2100 is plenty low. I wouldn't go any lower.
    Then again my Lexus at 80MPH is turning 1800....
  11. hotroddon
    hotroddon
    Yep, that was the way we always set them up before all this overdrive **** came along. And many cars came from the factory pretty close to that as well. now everyone is spoiled and forgot (or never knew) the way it was.
  12. Fenders
    Fenders
    Well you never said WTF your rear ratio is, but 2100 sounds fine.
  13. Louie T
    Louie T
    I don't know what the rear end ratio is. Maybe someone could chime in. Its a stock 58 cadillac rear end. I really appreciate everyone's input. I was just thinking of taking advantage of the torque this beast makes. Maybe I should just shut up and drive. Lol.
  14. theHIGHLANDER
    theHIGHLANDER
    Any less RPM at 70, I'd bet it would be a dog at lower speeds (MPH). If you stomp on it at 70 and dive into a lower gear, I'll bet it puts a childish grin on your face that you can't control. And this just in: 8600lb Duramax @70MPH, 2100RPM. Stomp it into p***ing gear and I grin too:cool:
  15. Louie T
    Louie T
    You've seen me driving around town haven't you.
  16. hoop98
    hoop98
    from Texas
    1750 would get you about 1.5-2 MPG
    Losing about 5HP to friction maybe 1 to pumping.
  17. OldColt
    OldColt
    From an old automotive performance book.
    1. Gear your car to run at it's engines peak torque RPM at your desired cruising speed for a good combination of throttle response and economy.
    2. Gear your car to cross the finish line at it's engines peak horsepower RPM + 5-10% for drag racing.
    3. Split the difference between 1 & 2 for a street/strip car.
    --- Steve ---
  18. need louvers ?
    need louvers ?
    I have my Plymouth set with a Tremec TKO and a 3.23 geared Chrysler 8 3/4" rear end. 75 comes up at 2175 or so. Damned comfortable for loafing about town, and even with an aluminum headed, humpity 360 at about 420 HP, turns back about 20 mpg on the many long road runs I have done with it. I have on several occasions thought about bumping the rear gears up to more in the 3.55-3.73 range, though. The reason behind this is that it is soooo happy in the 2450-2550 range that I find myself running that RPM range allot on long trips. Unfortunately, that's right at 100.... Great for the western Arizona Autobahn chingo, just not so great where that sort of thing is a less tolerated kinda deal.
  19. sololobo
    sololobo
    Sounds like a nice rpm level at 70 to me. Might be luggin that big block at lower rpm's. judt sayin. ~sololobo~
  20. My setup runs 1750 at 69 mph and returns 20mpg. Unless you have more duration than will work at low rpm or your induction system has some problems, you have no reason not to lower the cruising rpm some. The operating range of the cam profile is a huge factor here.
  21. Fenders
    Fenders
    Put in neutral. Jack up one rear wheel. Turn it two revolutions. count the revolutions (and fractions) of the driveshaft. That is your ratio.
    i.e. 3 driveshaft revolutions is likely 3.08
    3-1/2 is likely 3.43
    just over 4 is likely 4.11
    Look up available axles ratios for your car, that will get you close when counting the driveshaft revolutions.
  22. tfeverfred
    tfeverfred
    Sounds like you have a nice economy setup. That's the main idea behind that 700R4.
  23. hoop98
    hoop98
    from Texas
    3.07 was standard in a 58 Caddy.
    Must have the optional 3.37
  24. tfeverfred
    tfeverfred
    Hoop, you got a link to that calculator? I lost mine in a computer crash.
  25. hoop98
    hoop98
    from Texas
  26. seb fontana
    seb fontana
    from ct
    Put a vacuum gage in an go by what it says...Highest vacuum is where it would be best..
  27. tfeverfred
    tfeverfred
  28. hoop98
    hoop98
    from Texas
    she ain't breathing right!
  29. powrshftr
    powrshftr
    I'm around 4000 at 70mph,so I'm the wrong guy to ask....lol
  30. patrick66
    patrick66
    That sounds pretty good, what you have! My '66 Dodge turns 2,900 RPM @ 80 mph with 3.23 gears and a 1:1 Third gear.
