39 or 40 Ford belt trim HELP
Discussion in 'The Hokey Ass Message Board' started by abchurch, Jun 30, 2013.
  1. abchurch
    abchurch
    from Lodi, CA
    Is there a tool available for installing the belt trim on 39 or 40 Fords? I don't want to scratch the paint trying to squeeze the wire trim clips while trying to shove them thru the body holes.
    I'd appreciate any tips towards getting my 39 Ford convertible trim on without paint damage.
    Thanks in advance
  2. HOTRODPRIMER
    HOTRODPRIMER
    You can run some low tack masking tape above and below the trim hole,,that's the way I have done it in the past. HRP
  3. abchurch
    abchurch
    from Lodi, CA
    HRP, I did tape above and below. I just can't squeeze the clips to get them to seat into the holes. I've tried waxing the clips but that didn't work. How have you been able to push them into the holes?
  4. HOTRODPRIMER
    HOTRODPRIMER
    Rubber mallet,,it doesn't take much. HRP
  5. okiedokie
    okiedokie
    from Ok
    Good hard push got mine in without any paint damage.
  6. olscrounger
    olscrounger
    Just a firm push on all the 40's I've done-just make sure the trim is gonna line up prior--pm me for more info if you need
  7. 39 Ford
    39 Ford
    Heel of my hand has always worked for me.
  8. fordor41
    fordor41
    If there're used clips sometimes they get distorted. Try new clips and I put some grease on my fingers and coat the ends to help them into the body holes.Then I use the heal of my hand. Painter tape idea helps also.
  9. papa's 39 koop
    papa's 39 koop
    I wrapped a shop towel around a paint paddle,made sure clips were lined up properly.light tap with plastic hammer.Most of them went in with a firm push though
  10. olscrounger
    olscrounger
    a few things---
    -make sure your body lines are correct door to 1/4 and door to cowl
    -may have some paint buildup in the trim holes--if so,run masking tape over the holes and carefully file out with a small round file
    -install the door trim
    -on a 40 1/4, cover the trim holes front to back with masking tape-now put the bolt on clips on the front edge and rear of the trim piece-bolt to body over tape--now ck trim alignment
    -at this point you may have to file out 4 or 5 holes back on the 1/4 to get the trim aligned--then run tape above and below and install trim-if hole are clear and clips are good they should pop in with the heal of your hand
    -seal all trim clips inside door and 1/4
    -may have to do the same on the hood side trim to get a good line
    Just installed trim on a 40 last week using these methods
    Hope it helps
  11. abchurch
    abchurch
    from Lodi, CA
    OK guys, thanks for all the good responses. I gave up on pushing the wire trim clips and instead made up clips using 1/2 x 5/8 x 18 ga with 10-24 x 1/2 pem studs and serrated flange nuts for all holes. Lotta work, but worked great and got perfect trim alignment.
    Thanks to all.
    abchurch
  12. Dak Rat
    Dak Rat
    from NoDak
    ab, thats how I did mine. Yes, a lot of work but the results were worth it. Trim fits very snug to the body and the paint around the holes doesn't get all chipped up and make a place for rust to start.
  13. go-twichy
    go-twichy
    I had a Datsun roadster, and that's how I put them on. I made the little plate part out off br*** so it wouldn't get rust drip marks. been on there since 1988.
  14. gmc1941
    gmc1941
    Flexible BX has red plastic bushings which could be trimmed and incerted into the hole to protect the paint. IMOP. I think being very careful you would still chip the paint. No easy way.....
  15. Hot Rods Ta Hell
    Hot Rods Ta Hell
    On a similar car, I tied nylon string to the trim clips, p***ed it through the holes, lined up the holes then had a helper pull the line from the back side while I pushed on the trim with the heel of my hand outside.
    Every time I go through a time consuming, stressful, tedious ***embly step like this ( ie. aligning 34 Ford grille and hood! ), I always wonder how quick and easy the step would (have to) be done on the original ***embly line.
    Imagine some guy with a stack of stainless trim popping these things on in less than a minute as the car rolled by on the ***embly line-all day long. No issues, no stress, no chipped paint. Bored out of his mind. Could probably do it blind folded.
  16. 325w
    325w
    Wasn't that bad in the factory in the early sixties. We had all new clips and never touched by human hands parts. Even had time to run get a drink of water.
