pic request...T on A
Discussion in 'The Hokey Ass Message Board' started by Dan, Oct 14, 2005.
  1. Dan
    Dan
    got an idea floating around in my head, anyone got any pics of a T ('gl*** or steel) on an A frame??
  2. 27pickemup
    27pickemup
    from AZ
    here is my t and a
  3. fivespoke
    fivespoke
    from Wichita KS
    Here's one of mine.
  4. grumper
    grumper
    Hey 27pickemup, you got any more pics? I am in the process of building the same thing, I haven't seen many pics of 27 RPUs.
    grumper
  5. Just Gary
    Just Gary
    27pickemup, your car has a great rubber rake. what sizes are the wheels and tires?
  6. Gregg Pellicer
    Gregg Pellicer
    Here's one of mine ,I hope if i can get pic posted
  7. TRod
    TRod
    This is the progress of my '27 on a Model A frame. It is Z'd 2" and chanelled another 4". I am running a flathead and banjo rear with a 3spd. ****** (open drive).
    Tony
  8. AZAV8
    AZAV8
    from Tucson, AZ
    Try the November 2005 issue of Street Rodder. Article ***led "Forever Young" has some nice pictures and a good build article of an A frame. I looked at their site, for the article but its not up so you have to go to the paper magazine.
  9. I put a pic of mine on here a while ago. It is still in the shop and some don't like it because it is to tall. It looks better in person than it does in the pic. Check my prior post to see it. I don't have a way to post another right now. It's a 26 on 'A' frame with 48 ford pick up motor mounts a crossmember and a 40 merc flat motor with 2 97's. Open drive line 46 truck rear and 'A' spring. I Like it, road sign floors and all.
  10. 27pickemup
    27pickemup
    from AZ
    those are 33 x 12.5 bfg light truck tires on the back... 295 60 15's on the front.
    i need to find another tire about 31 inches tall for the back because the light truck tires do not hook..too hard of rubber i am thinking other than that they look cool.
  11. 27pickemup
    27pickemup
    from AZ
    here is a link to a few more pics...http://www.clubhotrod.com/photopost/showgallery.php?ppuser=12623&cat=500&thumb=1
  12. 27pickemup
    27pickemup
    from AZ
    here is another pic.
  13. muffman58
    muffman58
    Here`s my abomination. 27T on a 29 frame.
  14. muffman58
    muffman58
    Dam, that`s a good lookin truck! Get outta my head! I`m running 285/70/15 BFG`s or rear & 205/60/15 on front. You do very good work my man!
  15. Dan
    Dan
    what issues are their concerning mounting the T body on the A frame?? Any firewall clearance issues?? good looking stuff guys...
  16. BlackFlag
    BlackFlag
    Abomination my ***, that looks like its going to be a bad *** ride.
  17. 27pickemup
    27pickemup
    from AZ
    thanks keeps me out of the bars...oops the fronts are 195 60 15's i dont know what i was thinking before
  18. How about a 27 T on a Z'eed, pinched and boxed 21 T One Ton Truck frame?
  19. MBL
    MBL
    Got one here.
    Tim
    MBL
  20. muffman58
    muffman58
    I can`t seem to find any pics at that location. You got any more you can post? I`m kinda stuck on a few things and would like a little more inspiration! Did you run a underfloor master? Or did you put in under the dash? Also need to make or buy a windshield frame. I have the posts that I chopped some, but no frame. Any build pics? Again I think that`s one cool RPU!
  21. muffman58
    muffman58
    Very simple mounts. Basically, there a small double gusset on the fronts simillar to a stock mount on the inside of the frame rail & the rears are the same on the inside of frame but connect to the stock rear crossmenber of the body. Firewall issues where not a problem, but then again I went with a Ford motor so no dist clearance problems. Chevy motor or rear dist motors would need a bubble in firewall. It`s what I had so its what I used! If I had a camara worth a **** I would post some pics of the body mounts. Like I say though, very simple!
  22. 27pickemup
    27pickemup
    from AZ
    do you have an e-mail address? i could send some pics to ya there.. most of all build pics are not digital. but i have a few.......... underfloor master yes 78 mustang, 85 corvette front discs, 75 maverick rear, 8' z in the rear 6" drop front axle 48 merc steering column, 37 ford taillights, 72 vega steering box, guide 682c headlight -w- h4 lenses, i cant remember but i think i cut 12" off the bed. ladder bar rear suspention w coil overs i bought my windsheild frame from speedway, a little tweaking it works. now i have to figure out what the hell to do about interior..
  23. 27pickemup
    27pickemup
    from AZ
    i welded in the front part of a chev oil pan for my distributor relief on mine
  24. muffman58
    muffman58
    Thank`s You can e-mail me at crowley8@cox.net I really do appreciate any pics you might find! I saw the lower windshield frame at Speedway , but haven`t really decided what way to go yet! I say another post on here about a Duvall type frame from a place call Poly-Form and I`m still thinkin on that one, or the one from Speedway! Lots of money for these, but like I say I`m still thinkin! I`m also curious about the inside of the bed on yours. Did you go with wood, or something else? I haven`t shortened my bed [ YET? ] because I can`t decide on that either! Mine is a old touring body so I have room to make the wheels meet at the original bed outlines. I`m on a 108'' wheelbase.
  25. 27pickemup
    27pickemup
    from AZ
    i did a metal bottom with a kickup in the middle for frame clearance..
  26. MG-Bs have solid aluminum WS posts, I've seen a guy reshape the bottoms and make a centerpost to make a Duvall type WS.
  27. metalshapes
    metalshapes
    My '23 on A rails.
  28. Paul
    Paul
    Editor
    mine again
  29. Paul,
    Is the windshield stock height? Looks like it - would you shorten it any - since you were able to drive this or would it be too short. I am going to be pretty low in my Touring - I should probably just buy some posts and start cutting. :rolleyes:
  30. Paul
    Paul
    Editor
    yes and, no.
    this is the look I was after :)
