54 royal
Discussion in 'The Hokey Ass Message Board' started by SSD, Aug 11, 2013.
  1. SSD
    SSD
    I made a deal on a 54 royal with a red ram and the 2 speed auto i was wanting to put a tilt column in and a different intake/carb setup is there a way to make a floor shifter work with that trans
  2. Jalopy Joker
    Jalopy Joker
    congrats -post some pics of your new ride - outside, inside, under hood
  3. 29Jay
    29Jay
    from Ft Worth
    We have a '55 Custom Royal that we are working on.
  4. George
    George
    The 270 4V intakes fit, and there are after market intakes for the low deck 241/270 Dodges group of engines.
  5. 73RR
    73RR
    If you are a really good fabricator than a tilt column is doable, but certainly not easy, same deal for the floor shift...all custom fab.
  6. stillrunners
    stillrunners
    from dallas
    Wonder how a 55 mopar dash shifter could be converted for the floor ? When I run across old Dodge Motor homes - I'm grabbing the shifters out of them to maybe use on my 56 or a D300 truck build I'm doing...
  7. SSD
    SSD
    as fas as not hurting the trans the shift linkage would be cable operated and the throttle valve could stay hooked to the carbs correct
  8. SSD
    SSD
    so nobody knows about this trans or if this will work
  9. George
    George
    Post #5 covers it. The PowerFlite isn't much of a ****** compared to the 727. Parts are getting scarce & you'd still have an ancient 2 speed. I'd get an adaptor from "73RR"(there are others) it's just a shame the 904 won't work on the small CID Hemis.
  10. 73RR
    73RR
    Take a closer look at your existing system, or, better yet, buy a service manual. For this a Chilton will suffice.
    You do have kick-down linkage but it is connected at the accelerator floor plate ***embly, not at the carb.
    If you swap to a later trans this could work, again, depending on your fabrication skills....however, I have never seen/heard of it done.
    If you are still in the dark, please be specific with the question so we can help. Oh, and try some punctuation, just for us old guys...
  11. da dodge brother
    da dodge brother
    from wisconsin
    George ...Ran a 904 on my '55 270 Hemi for two years until I discovered the A518 (46RH). Had to use the adaptor from Wilcap but it worked out great. The overdrive is a nice setup though. 23 mpg on the hiway running at 1800 RPM.....
  12. SSD
    SSD
    the 46rh uses the same adapter as the 727?
  13. George
    George
    OK, I was thinking there was a problem getting the starter to fit with the 904.
