BIG bore piston issue..........
Discussion in 'The Hokey Ass Message Board' started by skidmarks, Aug 12, 2013.
  1. skidmarks
    skidmarks
    from USA
    It split in half!
    Neat paper weight, but what's the story? Is it from a tech school? Salesman sample?
    Polished finish. 6" in dia
  2. big duece
    big duece
    from kansas
  3. blowby
    blowby
    from Nicasio Ca
    Interesting dome configuration.
  4. 69f100
    69f100
    from So-Cal
    x2 on the training tool, or maybe it was an old hot rodder who figured what they hay. the day i bought my band saw was the day every broken part in my garage got turned into a "teaching tool"
  5. Mike VV
    Mike VV
    from SoCal
    6" dia., four rings, probably aircraft.
    Mike
  6. Andy
    Andy
    Maybe aircraft radial engine. R-985??
  7. wolffcub
    wolffcub
    from Edmonton
    Clever piston design. Lets you replace half that has the most wear at
    half the cost.
  8. BobMcD
    BobMcD
    Matching ash trays.
  9. 40FordGuy
    40FordGuy
    Someone with too much free time..............
    4TTRUK
  10. JohnEvans
    JohnEvans
    from Phoenix AZ
    Yep aircraft. Radial engine I would suspect due to the short skirt.
  11. Piper106
    Piper106
    Is it exactly 6" diameter or around 6" diameter.
    Exactly 6" diameter would be Rolls Royce Griffon.
    Most Pratt and Whitney radials were 5-3/4" bore (R-1340, R-2800, R-4360).
    Most Curtis Wright radials were 6-1/8" bore (R-1820, R-2600, and R-3350).
    Allison V-1710 was 5-1/2" bore. Packard V-2500 PT boat engine was 6-3/8" bore.
  12. shadams
    shadams
    Actually that is a piston from Optimus Prime. His engine block would separate into several pieces when he transformed into his humanoid figure to allow for his walking motions. Weird you guys didn't already know that...
  13. Piper106
    Piper106
    I would start the betting that it is from a Wright radial engine. Boeing built a lot of planes with Wright engines. B-17 had four of the R-1820, and the B-29 had four R-3350s. Both 6-1/8" bore. Loose a little to a saw cut, and your at 6".
  14. Truckedup
    Truckedup
    Griffon had 4 valves per cylinders as did all V-12's from about the 1930's....That's a 2 valve piston....
  15. Mr48chev
    Done the way it is and done well I'd say it was used as a training aid in engine cl***es at one time or another. Easy to take off the shelf in the cl***room and show how a piston was made when you are discussing pistons in the engine cl***. Nice set of bookends now I'd think.
  16. CGkidd
    CGkidd
    That is pretty damn cool whatever it was for.
