1956 chevy truck rear fenders
Discussion in 'The Hokey Ass Message Board' started by coody, Aug 12, 2013.
  1. coody
    coody
    looking for some help here.just bought a 56 chevy truck short wheelbase.the rear fenders have the tail lights made in them.Out of all the ones i have seen they have a bracket mounted to the bed.I cannot find any pics showing them in the fenders.Need a little help thanks.it has chrome bumpers and stainless trim around windshield and doors and above the back window.
  2. Carbs & Chrome
    Carbs & Chrome
    By "made in them" I ***ume you mean "frenched". Sounds like someone has done a little customizing.
  3. Or you have later fenders that have reverse lights...
    Pics would solve this alot faster :D
  4. coody
    coody
    Ok the reverse lights sounds like it might be for that.there not frenched they are factory.i will send some pic once i know how thanks yall
  5. If so, they are C10 fenders.
  6. brooksinc1976
    brooksinc1976
    from P-Town
    Here u go guys here's the pic. Yes I'm pretty sure they are factory. ImageUploadedByH.A.M.B.1376428959.207793.jpg
  7. Dane
    Dane
    from Soquel, CA
    I'd bet $100 they are custom...
  8. rusty1
    rusty1
    ...you'd lose your hundred; those are factory back-up lite mounting points.
    my 55 has the left fender like that, the other one doesn't have that dimple, so likely the left one's a newer fender...
  9. jcmarz
    jcmarz
    from Chino, Ca
    He wins, that's a custom job. Only the Cameo had reverse lights
  10. F&J
    F&J
    Late 65 and all 66 step fenders had backup lights mounted in a fender dimple. Fenders fit from 55-1/2 to 66.
    Without looking on web, I can't recall a factory dimple looking that complex, but time erases memory;)
  11. lakeroadster
    lakeroadster
    from *
    Let me help clarify that memory ;). I have a '65 stepside C10 so I have done a bit of hunting and searching for parts... I found this in my archive files:
    "The rear stepside fenders on the 1955 (2nd series) through 1966 are usually considered the same. The reproductions on both metal and fibergl*** are listed in catalogs and related adverti*****ts as being identical on the right and identical on the left.
    Not true if you are a perfectionist! In 1966 Federal automotive regulation required all cars and light trucks to have back-up lights. Thus, GM modified this fender with a stamped indention to better fit the required back-up light ***embly."
    http://www.oldchevytrucks.com/blog/?tag=1966
  12. T.W.Dustin
    T.W.Dustin
    so very likely someone swapped in '66 fenders - nice detective work
  13. Buzznut
    Buzznut
    I had no idea that the '66 fenders had that dimple. Definitely not stock on a '56...
  14. Dane
    Dane
    from Soquel, CA
    I had a 65 stepside and never saw any fenders like that. Yet another lesson learned on the HAMB... [​IMG]
  15. F&J
    F&J
    What else did you research on the actual light itself? I think I recall there were GM factory accessory back up lights before the FED deal. I kind of remember those being on a simple steel plate bracet bolted to the rear bed post?
    And some Chevy trucks or at least suburbans from around 63 up?, used the 55 front park light chrome bezel and white lens as back ups. Those had lenses with the "55" guide code as I recall.
    But it seems I recall a bigger, maybe flat dome shape on the pickup back up light, just a year or two prior to 66?
  16. dubie
    dubie
    I think he may be thinking about the fleetside bed tail lights. A lot of guy run the fleestide bed on 55,56,57 Trucks
  17. hotroddon
    hotroddon
    here is what they looked like on the stock 66 only application
  18. lakeroadster
    lakeroadster
    from *
    Check out Persh's website link here, I think your memory is a lot clearer than you give it credit for.. :Dhttp://www.persh.org/pickup/BackupLights.htm
    The optional light had a rubber "pad" that fit the stepside fender contour, the std '66 light didn't need the pad. The fender isn't flat in this area. I know this because I mounted some '64 Impala taillights in my '65.
    More Options:
    No dimple, the light shines a bit upward (especially with the stock stinkbug rake these trucks had from the factory).
    The dimple gives the light an al***ude adjustment and a flat mounting surface.
    My '64 Impala taillights, I mounted them upside down to get the angle a bit more level:
  19. jcmarz
    jcmarz
    from Chino, Ca
    That's a early 60s C10 rear fender on that truck. All the info shown here points to the early 60s C10 as to having those reverse lights mounted on the rear fenders. But in 1956, Chevrolet did not offer factory installed reverse lights on their trucks (except on Cameos). Heck, a second taillight was a extra paid option.
  20. GroundPounderSATX
    GroundPounderSATX
    very cool how that all worked out!
  21. coody
    coody
    Thanks for all this info.i really learned something today!!did they make a duluxe in 56?this truck has stainless trim around the windshield,both doors and around the back or this standard?
  22. jcmarz
    jcmarz
    from Chino, Ca
    They made a Deluxe. Taskmaster trucks like yours had the stainless trim and a big back window (no small window Deluxe). My 1951 Advance Design Chevy truck is a Deluxe model, hence the 5 window cab and stainless trim.
