Windshield Rubber Gasket
Discussion in 'The Hokey Ass Message Board' started by pirate, Jan 28, 2010.
  1. pirate
    pirate
    from Alabama
    I am looking for a rubber gasket/seal to go between the body and a 3/16" thick Lexan windshield. Something that has a 3/16" channel the Lexan will slip into with a flat bottom or preferable a flange that will sit nicely around the curved section of the cowl. This is a sports car/track car I am building. Any help would be appreciated. Thanks
  2. 56don
    56don
    J.C. Whitney or Softseal.
  3. gary mundy
    gary mundy
    from Kansas
    steele rubber parts
  4. 55 dude
    55 dude
    check out the rubber in older large van and suv windows as they are flat and rubber mounted. the newer stuff is glued in.
  5. skidsteer
    skidsteer
    Get a catalog from Restoration Specialties. They give dimensions, and have actual size diagrams of the cross section. Also at: restorationspecialties.com
  6. dunstan
    dunstan
    I'm also looking for a 3/16 gasket for a lexan windscreen. Did you ever find a suitable one?
  7. 48FordFanatic
    48FordFanatic
    from Maine
    Also check McMaster-Carr on line.
  8. saltflats
    saltflats
    from Missouri
    Have you stopped at you local gl*** shop to see what they have.
  9. dunstan
    dunstan
  10. tin_indians
    tin_indians
    Definitely try steelrubber.com
    They have a few pages you can check out profiles of rubber like yours. I'm willing to bet they have what you need.
  11. dunstan
    dunstan
    Having sent them the profile and measurements they said they have nothing that matches, not that would fit 3/16. It seems none of the rubber companies do, from my several days of research.
    Instead I'm looking into just bonding the lexan directly to the frame, like modern cars do. Now I just need to figure out how to get a decent frit band on the lexan to protect the urethane from UV.
  12. Hemi325
    Hemi325
    from Boerne, TX
    Try Metro Moulded Rubber in Minneapolis.
  13. dunstan
    dunstan
    Some good options there, thanks! I'll give them a call in the morning and see what the specs are.
    (The problem, if it's not clear, is that safe 3/16" thick auto windshields are something of a modern invention, where as rubber gaskets are old school. It seems as though there's little, or no cross over.)
  14. slddnmatt
    slddnmatt
  15. Turbo26T
    Turbo26T
    Why not wrap the perimeter of your gl*** in a setting tape,to bring the thickness from 3/16" to 1/4" .After its installed , just trim off the excess...Setting tapes are available in lots of thicknesses & widths..You might want to glue it to the gl*** before trying to seat it in the w/strip...
    Here's a link with some examples of gl*** setting tapes
    http://www.gl***warepro.com/key/auto-gl***-setting-tape
  16. 1934coupe
    1934coupe
    Steele rubber has profiles that fit almost everything check them out.
    Pat
  17. dunstan
    dunstan
    Unfortunately neither Metro nor Steele Rubber have anything suitable that fits 3/16, but the setting tape idea sounds promising, thanks Turbo.
  18. mike in tucson
    mike in tucson
    from Tucson
  19. dunstan
    dunstan
    Ahhhhhhhthankgod. After my 3rd call to http://www.opticarmorwindows.com they finally realized that my order of 3/16" hadn't actually shipped, so they were able to swap it out for a 1/4", thus making the entire problem go away. Now I can just use the regular stock gasket. What a kerfuffle!
    Thanks for all the help and advice, though, I really appreciate it.
  20. BobsurUncle
    BobsurUncle
    from Tracy, Ca.
    Go to you a local gl*** shop. All these gaskets are available from a place in Union City. You probably can't buy from them direct, so hit up a shop. These are all for 3/16-1/4" gl***.
