Woodward Fab VS Harbor Freight Bead Roller
Discussion in 'The Hokey Ass Message Board' started by chevelle bob, Aug 14, 2013.
  1. chevelle bob
    chevelle bob
    from Linton
    Sorry but I could not find an answer to this question with the search function. Woodward makes a bead roller that looks like the HF one, which is better? I know they are both cheaper units but I am putting in floors and will probably only use it for this project so hate to sink a lot in one. Any ideas would be appreciated.
    Thanks,
  2. chevelle bob
    chevelle bob
    from Linton
    I also have been looking into ways for putting in ridges without bead roller. There was a tech article on here some time ago about using welding rod and beating the pan around it.
  3. BILL54
    BILL54
    from oHIo
    I purchased the woodward fab one, its alot heavier than the harbor freight roller. I added bracing to mine to stiffin the frame.
  4. vega1
    vega1
    Ok so I bought a roller shear brake combo from h.f. It looked just like the one Woodward had. Not so. Tried to shear one piece of sheet metal busted in two at the main body that is like a inch thick the casting was damn near hollow. And was full of porosity and I was only shearing 20 g metal their **** is junk it was the first and last
  5. HOTRODPRIMER
    HOTRODPRIMER
    No real contest,,both Woodward and HF offer a off shore bead roller that the only difference I am aware of is the paint color.
    I have the cheaper HF roller and my friend Dave has the Woodward :rolleyes:
    Woodward does offer several other nicer and better built bead rollers but there is also a huge price difference. HRP
  6. 64Cyclone
    64Cyclone
    I also have a Woodward roller and the main body is thicker and shafts are larger than the HF one. But it still could use some bracing. Mine flexes some when doing 18g steel.
    I didn't like the crank handle and a member here made me an adapter to put a Grant style steering wheel on instead. Much easier.
    Since you have to brace it anyway, you might want to get a HF roller since another member here makes a variety of roller dies so it's more versitile. I can't remember if he's making them for the Woodward or not.
    For the money, this one looks like a good deal since it comes with a stand and appears to be stronger. And it's US made. Never heard any reviews on it though.
    http://www.ebay.com/itm/TP-Tools-20..._Automotive_Tools&hash=item519f1f7995&vxp=mtr
  7. HF is always a ****shoot... FWIW, I have a HF bead roller as well as a press brake/shear and haven't had any issues. But as noted, most of the 'other' brands are just the same thing with different paint, so whatta ya do....
  8. sko_ford
    sko_ford
    I got a woodward one. the shafts are 1" asapossed to 22mm. The guides also hve grease zerks. But other than that it looks the same. I also saw bailiegh has a similar one. But I haven't seen one up close
  9. Slimmey
    Slimmey
    I bought the one from eastwood, don't know if it's the same as the others, it works good with the exception of the crank handle ****s. In the middle of mounting it on an old upholstry sewing machine. Hard to get it slowed down, so I'm looking for a garden tractor belt driven hydrastat system, that way I will have full control of speed and reversability. Make it a one man operation.
  10. Slimmey
    Slimmey
  11. alchemy
    alchemy
    Do you pump the sewing machine's treadle to roll the beads?
  12. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Either one will require beefing up to prevent distorted beads. Get the cheaper one and start reinforcing it in all the right places. There are tons of threads here on this exact topic.
  13. hotroddon
    hotroddon
    I have the HF one and it flexes like Gumby after a night of binge drinking.
  14. willymakeit
    willymakeit
    I rebuilt my HF roller. I'm going to try and adapt a HF thread machine to it like I'm using on my tube roller. Don't believe it will be to fast,just need the time.
  15. Slimmey
    Slimmey
    No alchemy, it's eletric mtr. The motor runs full out 1300 rpm the pedal controls the veriable speed clutch belt engagement.
  16. HOTRODPRIMER
    HOTRODPRIMER
    You are lucky,,this is what happen the second day I used mine. HRP
  17. chinarus
    chinarus
    from Georgia
    Slimmey
    RE: " it's electric mtr. The motor runs full out 1300 rpm the pedal controls the variable speed clutch belt engagement."
    So you just removed the sewing head and found a pulley to fit the shaft ?
    I have an old Singer straight s***ch that has a new clutch motor setup.
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    I realize budgets sometimes enter into the choice of things you can buy, I have a budget like most people. But sometimes, especially with tools and equipment, if you spend a few dollars more you get so much more.
    We have a Pro-Tools motorized bead roller and it has really made work so much easier. No flexing at all, and it even lets me make straight or curved beads that come out pretty good looking.
    For example, I know the HF one goes for about $ 200 and I imagine the Woodward Fab one goes for about the same. The Pro-Tool hand crank one is a little more at $ 450.00 but it requires no reinforcing to make it work like it should. The motorized one is a little more at $ 750 but it lets one person do the job by himself and is easy to control the speed on.
    There are more expensive ones on the market but this one does everything we need it to do, and it is made in America.
    Don
  19. 29moonshine
    29moonshine
    get the hf one it comes with the dies. you can get it on sale for $100 then beef it up
  20. My HF as modified with masonite table and angle iron fence, works great. But it still ****s for some jobs as the throat depth is only 18", the 24" would help on some projects.
    The T handle or a quick form of adjustment here is a must as you will be opening and closing this adjustments more then you know! :D
  21. ALEISTER
    ALEISTER
  22. BAILEIGH INC
    BAILEIGH INC
    Alliance Vendor
    Don't forget Baileigh has a small army of HAMB'ers that are running our bead rollers. If you are a HAMB member you get a pretty slick discount on top of free promotion of your builds on our website.
    just give me a call direct for the hookup 920-482-3220
  23. heatnbeat
    heatnbeat
    from Madera,Ca.
    I had. HF bead roller and gave it away! I ended up making my own. The upper shaft moves in/out 1-1/4" the shafts are 7/8" and the ends turned down to 20MM with a 6MM key way ( matches Lazze's bead roller ) I haven't bought any beading dies from him yet, I made my own.
    It is powered by a 3 phase gear motor 98:1 and a 120volt in 220 3phase VFD. Variable speed, forward/reverse pedals 24" deep. The sides are 3/8" with
    1x1-1/2" bar top, back, and bottom then 1/2" on the sides rear half. I can bead up to 16 gage with it!:)
    Sergeant82d likes this.
  24. Cyclone
    Cyclone
    from Sonoma, CA
    We have the Woodward, put a ring off of a dept store clothing rack on it. Have only done a few things w/it so far.
  25. sko_ford
    sko_ford
    That is a big hoop sir
  26. ryno
    ryno
    If you really only think you'll use it one time, I'd suggest finding someone in your aera that has a nice one and just pay them to make the beads for ya. They shouldn't charge you more then a hr or so of shop labor time.
    You'll be more the dissatisfied with the outta the box performance of a Woodward or HF unit.
    I have a baileigh power unit and love it.
