Projects 1964 Falcon B/FX Build Thread
Discussion in 'The Hokey Ass Message Board' started by fiveoh108, Nov 29, 2011.
  1. DavidY
    DavidY
    from 15102
    Well, since you mentioned the T-Bolt, here's the first one, the last one and one in the middle. I think the red one is the final one made.
  2. fiveoh108
    fiveoh108
    That is an amazing car collection..
    Just got home from work, look at what found! ImageUploadedByH.A.M.B.1376646801.675091.jpg
  3. powrshftr
    powrshftr
    Oh hell yeah!
    Betcha a dollar you stayed up all night getting it back on the car too,didn't ya..?
    Congratulations Mike!
  4. tommyd
    tommyd
    from South Indy
  5. 65COMET
    65COMET
    Mike;it is about time they got it back to you!!!Did they give you any information on the "NEW" system? ROY.
  6. Thefalconkid
    Thefalconkid
    Well? How does it run now?
  7. fiveoh108
    fiveoh108
    Not much info, just said to run it! I went to Napa and Oreillys, neither had intake manifold gaskets, napa ordered them and they will be in tomorrow morning.. I also need to get another filter between the hilborn pump and barrel valve. I have seen some guys run a cone shaped metal filter that slips inside an -AN fitting, but I can't find them anywhere
  8. frankenfords
    frankenfords
    from SoCal
    You might try Oldie's Speed Shop in Ventura on Telephone Road in Ventura. They have a room full of AN fittings!
  9. 65COMET
    65COMET
    Mike;which intake gasket do you use? I have a couple of different types here if you strike out at NAPA. ROY.
  10. fiveoh108
    fiveoh108
    It's the ones with the L shaped ports for the water jackets, I got them today, just getting off work now. Maybe get it installed tonight
  11. Thefalconkid
    Thefalconkid
    Well at least one injected falcon will be running this weekend, and after waiting so long for Hilborn to get yours fixed up, I'm glad it's gonna be yours. Mine was getting close, until I realized I ordered the WRONG starter!! Let the return/exchange nightmare begin!
  12. powrshftr
    powrshftr
    If you didn't stay up all night to get it together and running,then take it to the track today and beat it like a rented mule,I will be very disappointed in you.
    Tell me you got it together....?
  13. fiveoh108
    fiveoh108
    I had some personal issues this weekend, but for the old gaskets s****ed off, the nozzles and hoses installed. I might get the injector manifold installed tonight after my 5 yr old goes to bed. And living in Southern California, there are not too many tracks around I could even go to!!
  14. powrshftr
    powrshftr
    Sorry to hear that.Hope everything worked out.
    Life has been getting in the way of my projects lately too...I don't mind though.I'm enjoying that phase where my Boy is old enough to help me work on the car,but young enough that he isn't too cool to hang around with Dad..:)
  15. fiveoh108
    fiveoh108
    Got the manifold installed, but now another problem! With the straight nozzles I can remove to service, the hoses are too close to the valve covers and I can't get the hoses screwed into the nozzles. So I guess I have to notch the valve covers out for all 8 hoses,I can't think of what else to do?
    ImageUploadedByH.A.M.B.1376899151.832562.jpg ImageUploadedByH.A.M.B.1376899165.796908.jpg
  16. powrshftr
    powrshftr
    I think you should be ok notching the gasket rail of the valve covers on the intake side.There will be such a small amount of material removed that it will never have an effect on sealing.
    Nothing is ever easy though,is it?Im constantly running into the 'domino effect' on my ongoing project too....you fix one thing,and that requires mods to three more things...ugh.
    Oh well.Screw it!We get to drive old cars that go scary fast when we're done..!:)
  17. wrenchbender
    wrenchbender
    Those fittings are an style and you can buy 45 degree adapters for them I know those adapters cost money but it would be a bolt on item and you wouldn't have to cut on those *****in valve covers you have an awesome car
    Chrome don't get ya home
  18. 65COMET
    65COMET
    Mike;try using two gaskets glued together,it may raise the VC high enough to clear.If not,it looks like just a minor slot ground into the gasket rail will work. ROY.
  19. Thefalconkid
    Thefalconkid
    Mike, I have the same valve covers, the rail is WAY too wide. I wouldn't notch them, but I sure would mill about 1/4" off that side of each cover.
  20. DavidY
    DavidY
    from 15102
    Wrenchbender has the answer. Angled or 90 deg fittings are the way to go.
  21. fiveoh108
    fiveoh108
    I had 90 degree nozzles before, part of servicing a hilborn injection is removing the nozzles to clean them, one slightly clogged nozzle and it runs like poop, trust me I learned the hard way!
    With 90 degree nozzles you cannot remove them with out removing the intake because they contact the heads, at least on my small block ford.
    I started looking those adapters wrenchbleeder, but if I make the nozzle taller with the additional AN fitting, the hoses won't reach!
    Roy two gaskets doesn't clear it either... I am thinking of just 4 half circle notches on each side, the hoses would fill the both and would not really even be noticeable I think.
  22. 65COMET
    65COMET
    I would notch the VCs,problem solved!! ROY.
  23. tommyd
    tommyd
    from South Indy
    Hey, just for the record.......I....We think you're due to catch a break. Sheesh! somebody pull that falcon of this guy. It's kicking his arss already!.:D
  24. fiveoh108
    fiveoh108
    It is kicking my A!! Lol
  25. Thefalconkid
    Thefalconkid
    I feel your pain! I got a falcon kicking mine too!!
  26. fiveoh108
    fiveoh108
    I'll call you in a little bit Brian.
  27. Thefalconkid
    Thefalconkid
    Tomorrow would be better, I'm beat & going to bed.
  28. 65COMET
    65COMET
    What a BUNCH of WIMPS!!! ROY.
  29. Thefalconkid
    Thefalconkid
    Mike, did you get a chance to ****on up & get it running?
  30. 65COMET
    65COMET
    Brian;Mike came over the other day to borrow my die grinder and cutting tools so he could cut his valve covers for nozzle clearance.I think between work and getting his Daughter ready for her first day of Kindergarten has him a little busy! ROY.
