Replacement engine is squirting oil out of a port behind the distributor cap?
Discussion in 'The Hokey Ass Message Board' started by mookiex4, Aug 15, 2013.
  1. mookiex4
    mookiex4
    from Reno, NV
    Hi all,
    I have a 65 GMC that I put a late 60s 283 into. It is ready to fire and wants to start. Before I fully commit and possible ruin the engine, I have an issue. The oil squirts rapidly out of a port on the engine right behind the distributor. I do not want to commit thinking something may be clogged and I do not know what this port is. The oil squirts against the firewall and straight down off of the transmission. I am thinking something is not hooked up correctly or this needs to run to the valve covers or is blowing off pressure because of a clog.
    Can someone help me out with this issue?
    Thanks,
    Mark:confused:
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    Port for oil pressure switch is open. Plug it with a sender or an 1/8" pipe plug.:D
  3. Apittslife
    Apittslife
    That is where most people attach the Oil sending unit, Or The oil line for a mechanical Oil pressure guage.
  4. pooboy
    pooboy
    from SoCal
    This is where the the oil presure line originates from. You need to plug it. Probably missing either the line connection or plug.
  5. Homemade44
    Homemade44
    That port is probably where the oil pressure sending unit is suppose to be installed.
  6. hoop98
    hoop98
    from Texas
    Sounds like the oil pressure switch is missing
  7. mookiex4
    mookiex4
    from Reno, NV
    Thanks all. I was leaning that way. I was hoping it would be for the oil pressure. It semed odd to me that oil would be shooting out in that area. I appreciate everyones ***istance in confirming.
  8. sheesh
    sheesh
    from canaduh
    damn, concurrence, can't be good lol
  9. propwash
    propwash
    from Las Vegas
    concurrence is good - next we'll discuss global warming
  10. tb33anda3rd
    tb33anda3rd
    that's one way to check for oil pressure. a gage is a better way.
  11. 2racer
    2racer
    only after he gets it running
