Customs Who's running Supremes on 6 lug chevy truck?
Discussion in 'The Hokey Ass Message Board' started by j-dogg, Aug 15, 2013.
  1. j-dogg
    j-dogg
    I want to run supremes and pinner whites on my 65 chevy. I think the thinnest adapter is around 2" thick. The wheels must be able to tuck because when aired out the rockers are about 1/4" off the ground. Do I have any chance of making this work or am I stuck with 6 lug steelies? Thanks
  2. Wowcars
    Wowcars
    I would swap the spindles, hubs and axle shafts with a '72 Chevy pickup and actually have 5 lug wheels.
  3. VNTGE41
    VNTGE41
    from l.a.
    nice truck man! i have a 64
  4. bonzo-1
    bonzo-1
    If your supremes are going to be painted, weld up the holes and drill new ones.
    I used the drum and a transfer punch. Easy and no aluminum spacers.
  5. Wowcars
    Wowcars
    I doubt he'd be able to do that with supremes. Some of the bolt holes will surely end up on the spoke.
  6. TLDLTD
    TLDLTD
    Killer truck!! The '60 grill looks nice!
  7. jchav62
    jchav62
    My '62 has been converted to 5 on 5 all around. I ran "Supres" for a while...
  8. FrozenMerc
    FrozenMerc
    Pretty hard to run a 5 spoke wheel like a Astro Supreme and make it look correct with 6 bolt holes. The bolt holes don't line up. Your best bet would be looking at swaping hubs and/or rotors like mentioned.
  9. rottenleonard
    rottenleonard
    I'm guessing he's talking about the new supreme knock offs that look like supremes but have six spokes and six lug holes. I saw them in a recent cl***ic trucks magazine.
  10. bonzo-1
    bonzo-1
    Sorry I was thinking of the "customs" Chrome slots
  11. Cerberus
    Cerberus
    Sounds like the best solution, if expensive mods are not required. Are the axles interchangeable with a '72 C10?
  12. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    6 spoke torque thrusts look odd
  13. slammed
    slammed
    Bing-o! Or custom inset/offset your stock steelies and then have them Chromed.
  14. j-dogg
    j-dogg
    I was thinking of using 6 to 5 lug adapters. Might be cheaper to just swap the truck to 5 lugs.
    Anyone know what's involved with the swap?
  15. slammed
    slammed
  16. And better.
  17. Cerberus
    Cerberus
    I read all 13 of 13 pages at their website on 60-66 C10's. All I was able to glean is a 71-72 C10 12 bolt rear end is a direct bolt in, but will be 1.5" wider. This implies if you only use the 71-72 axles in a 60-66 rear end, the axles will have to be shortened at least 3/4" in length to fit. Then, hopefully the splined end will be adequate enough to bolt up.
  18. j-dogg
    j-dogg
    Yah I searched over there for 5 lug conversions. It seems like more trouble then its worth. Maybe I'll paint the wheels a different color for now. Here she is without the beauty rings...
  19. FrozenMerc
    FrozenMerc
    I had not seen those yet. Kind-of ugly IMHO.
  20. this and be done with the h***les
  21. hotroddon
    hotroddon
    Like a chick with three ***ties
