64 fairlane 500 air ride
Discussion in 'The Hokey Ass Message Board' started by Redheadedlefty13, Oct 20, 2012.
  1. farna
    farna
    You're going to have a big problem with a rack and pinion if that one hangs too low. The inner tie rod ends must be level with the inner pivot of the lower control arm, with the tie rods parallel with the control arms. You can get by that if you can mount the outer tie rod ends ON TOP of the control arms. You'd have to weld up the lower portion of the hole on the end of the steering arm (not all the way closed, just to the small end of the tie rod end) and get a tie rod end tapered reamer (Speedway has them) to reverse the hole. That or cut the end off and weld a ready made tie rod end bung on (I did that, but made my own control arms, and mine aren't upside down). Then you can mount the rack so that the tie rod ends are parallel with the control arms but about 2" higher. Then you're going to run into problems with clearance between the engine and rack. You might just want to keep a steering box since the linkage doesn't hand down quite as far as a rack would. You might be able to mount the linkage upside down too, but the pitman arm end would be an issue.
  2. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    Ill figure something out
  3. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    and the reason that one looks like it hangs down too low is b/c it mounts futher back on the frame then rack and pinion i would use would be inline with the tie rods
  4. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    actually after looking at this one, it might work
  5. Liam-B
    Liam-B
    from Melbourne
    That looks it will work sweet as. Is your car column shift? Can be a bit tricky keeping it with a rack conversion apparently.
  6. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    This is just an example..not mine
  7. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    plates my control arms this weekend
    and built my tubing bender stand
    started taking a wire wheels to all the grim on the engine bay and cut what was left of the towers off
  8. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    got a little dirty with the wire wheel today..time to start bending up some mounts
  9. Cortney
    Cortney
    WOW!! Looks great, but, I think you should go lower! Hahahaha!
  10. JakeDW
    JakeDW
    from Missouri
    Thinking out side the box nice.i bought a tubing bender years ago never have used it :eek:
    Jake
  11. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    i could fold the pinch weld under :)
  12. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    ya everyone told me to either buy drop spindles or a mustang 2...but i like doing things a different way
  13. 64ONEOFF
    64ONEOFF
    from Md.
    I reccomend a strut tower brace, Cutting those towers out really weakings the front of those cars. Just something to think about later.
  14. 64ONEOFF
    64ONEOFF
    from Md.
    I made this one, because I had hydraulics on mine for 17yrs. I beat the shit out of it. Nothing ever moved on mine. I noticed on my best friends 64 (CUT TOWERS OUT) for a big motor, Things started moving. So built a brace for him as well.... Good luck
  15. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    i was planning on building something like that out of tube...i started my mounts, but my buddy grabbed me 1 3/8" instead of 1 1/4" so it doesnt fit in my tubing bender..used up what little 1 1/4" i had laying around the shop
  16. Going to look at a 2 door 64 today after work. God I can't wait to bag it, stance just looks badass. Would you mind if I pick your brain a little bit when I get to the bagging stage? Keep it up!
  17. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    thanks man, been a while since i updated..havent had a day off in over a month. i have this weekend off so probably have some progress after this weekend
  18. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    well i messed with the front suspension a little bit and started cutting out the rear wheel wells. what a pain in the ass . After looking at my options i am considering just mustang 2ing it.. after i do a disk brake swap and figure out what to do for steering, i could of just done a m2 for that. Still up in the air with that tho
  19. 64ONEOFF
    64ONEOFF
    from Md.
    Any lead way, or new pics of progress? Keep me posted.
  20. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    well some updates...after considering my options, i have decided just to MII the front end. Better brake options, rack and pinion, drop spindles, ect
    car leveled up in the air
    and some rear wheel tuckage for fun
  21. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    going to have to raise the MII crossmember a little b/c it hangs lower then the pinch weld..and i cant have that
  22. 60galaxieJJ
    60galaxieJJ
    do it! and do it now! im loving this car
  23. Chris94L
    Chris94L
    Sweet car man. I'd love for my '63 fairlane mordoor to sit like that...
    Which 2 kit are you using there?
  24. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    actually got an ebay cross member for a mustang, got it for $260 shipped still need to piece together control arms and spindles..a good friend of mine owns a shop and i can get the rest of the stuff at cost..so waiting for him to get back to me
  25. Chris94L
    Chris94L
  26. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    I got the 2.3 block and pistion...still trying to decide..once I get the suspension done I will worry about the motor
  27. 64ONEOFF
    64ONEOFF
    from Md.
    So how's it coming? Any progress
  28. Redheadedlefty13
    Redheadedlefty13
    from Avon, Ohio
    been too busy with work and paying pills, hopefully will have some soon, just gathering parts right now
  29. ColinCS
    ColinCS
    Staying tuned to this one...I love Fairlanes and really like what you're doing with yours!
  30. bpawl
    bpawl
    from Aurora, TX
    1. 57-60 Ford F100s
    Man, hope your finding time to work on the car...waiting for an update :D
