Michigan title question......
Discussion in 'The Hokey Ass Message Board' started by teddyt, Aug 17, 2013.
  1. teddyt
    teddyt
    from U.S.
    ***le ?
  2. shawnspeed
    shawnspeed
    from Attica Mi
    Keep your receipts for the material you built the frame with, along with a photo do***entary of your build....also you will most likely have to go with the bonded ***le application process....Shawn
  3. wannadrag
    wannadrag
    from WI
    Sign the owners name and your golden.These messages boards isn't the place to be asking about a ***le bought for using on another car.
  4. 117harv
    117harv
  5. The only thing golden is the amount of gold you will need to pay the lawyer if things go wrong. Frame the ***le and hang it on the wall. Consider the amount you paid for the ***le as an "educational expense". Call the DMV and see what they say.
    Charlie Stephens
  6. derbydad276
    derbydad276
    go to the Michigan Secretary of State Office nearest you and pick up an application for a as built ***le frame the Missouri ***le like others have said unless you have an affidavit from the ***le owner or a copy of their death certificate its useless
  7. Rex_A_Lott
    Rex_A_Lott
    Go read the thread " T confi****ed because of engine number"
    Then go get all your paperwork in order before you turn the first nut.
    Michigan DMV writes the rules you must play by...like them or not.
    Never mention the ***le you bought in public again.
    Good Luck:)
  8. Car Fox
    Car Fox
    Yes the ***le will be of no use to you, just send it to ME!
