50 mercury flathead truck with a problem
Discussion in 'The Hokey Ass Message Board' started by Bob Scott, Aug 17, 2013.
  1. Bob Scott
    Bob Scott
    from St. Louis
    All original. This motor has no power in 3rd gear. 1st and 2nd are fine.
    What's been done to date
    Carb, fuel pump, points, timing, compression, gas cap, air filter, muffler all at or brought up to snuff.
    This is crazy! The truck is in very nice condition aside from this one issue and it's baffled anyone I've talked with. It seems like it's just g***ing out on the slightest hill or any acceleration in 3rd.
  2. Mike51Merc
    Mike51Merc
    Fuel supply? By the time you hit third, the bowl's dry and the pump can't keep up?
    I'd suggest checking fuel volume, not just pressure.
  3. GassersGarage
    GassersGarage
    On one of the road trip threads, the was a square bird that had a terrible problem with quitting/losing power on hills. He added an electric fuel pump just for hills. He discovered that his pump diaphragm was bad and fuel was leaking into the crank case so he bought a new fuel pump. The problem with hills continued. He eventually decided to blow out the fuel lines (which were originals) and they were clogged. I believe it cured his problem on the rest of the trip.
  4. and hows your vacuum doing?
  5. Just shooting in the dark but do you have overdrive?
  6. replaced an old gas stove with a brite shiny new one once( tried to make the old lady happy)but dangedest thing- every time she started the oven the furnace would kick in and run as long as the oven was on.. went through a BUNCH of techs triing to figger that one out.. finally a guy comes to fix something else, not sure what anymore and I'm telling him my little tale of woe and he says its simple- no ground on the gas line...seems the gas flow was building a static charge on the line running back to my furnace controller.. one strap later no more problems....some times its just the littlest thing
  7. rotorwrench
    rotorwrench
    Fuel lines can clog with varnish. The flex line from the firewall to the pump can have a pin hole that will cause the pump to draw air in and less fuel. Bad condenser in the ignition can also cause problems.
  8. FANTM58
    FANTM58
    Va***e advance , not working ??
  9. JohnEvans
    JohnEvans
    from Phoenix AZ
    Fuel supply or no advance would be my thoughts.
  10. Bob Scott
    Bob Scott
    from St. Louis
    Thanks guys! I'll be sure to p*** this on.
