lowering a 64 impala
Discussion in 'The Hokey Ass Message Board' started by Layton, Jul 25, 2011.
  1. Layton
    Layton
    Me and a buddy are going to drop his Impala but before he forks out the money to buy drop spring we wanna try to heat or cut the coils we got. I can see where the excessive heat could be a problem on the metal.what are possible draw backs of both ways and the proper way to do it if there is one
  2. Gman0046
    Gman0046
    DO NOT heat coils. The car will ride like ****. My 62 impala wagon has 2" drop spindles in the front and a nine inch Ford rear with cut coils.
  3. 1951Streamliner
    1951Streamliner
    from Reno, NV
    You should go do an intro in the intro section before the old timers get on your case. I cut two coils from my Pontiac in the front and it still rides good. I used blocks in the back
  4. slammed
    slammed
    Shorter length shocks. Cut 1 or 2 wraps (2" per wrap drop). Same for the rear. You need a coil compressor. And a seasoned veteran in auto mods to be there to guide you safely along.
  5. Harrison
    Harrison
    Cut two coils all the way around & see where it lands.
    JH
  6. djtwigsta
    djtwigsta
    Hydros... lol
  7. oldcarfart
    oldcarfart
    the '58's (same ch***is) had optional air bags, I had a Bel-Air 4 door ex-Nevada HP car with factory bags, ended up swapping them out with Air-Rides (this was 1968 time frame)
  8. Layton
    Layton
    Thanks for all the help guys
  9. niceguyede
    niceguyede
    from dallas
    By spring compressor you mean a jack right? Ive seen lots of people TRY to use a spring compressor on these cars and it is scarry!! I just use a jack IF the car is complete, meaning the motor and trans are in the car. Been doing it that way for 20 years with no flying springs yet. Cant say the same about spring compressors. I tried one once and the damn thing let go and damn near killed our shop kid!
    05snopro440 likes this.
  10. That sits really nice.
  11. 38Chevy454
    38Chevy454
    For safety I loop a length of chain around a coil in the middle of the spring and then around the frame, connecting the chain ends to make a loop. Loose enough i can use the jack to lower the A-arm, but if the spring should fly out the chain will keep it from causing harm to me or nearby objects.
    Cutting coils should use a cutoff wheel. Don't heat them, that screws up the heat treat in the spring. Springs are heat treated.
    I cut 1 coil and used drop spindles on front of my 59 El Camino, same suspension as your Impala. In back I just cut the coils, don;t recall the amount I cut, think it was 1.5 coils? See here:
    I should have never sold that car............. It went to Sweden, anyone over that area ever see it? Sold it about 5 years ago, so it may look a lot different.
  12. joe_padavano
    joe_padavano
    I've done it both ways with no problems either way. The trick to cutting springs with a torch is to submerge the spring in a bucket of water so that the cut line is just above the water line. This protects the heat treat in the rest of the spring. Yes, you'll anneal a small area next to the cut, but the effect of that will be negligible.
    Start by cutting 1/2 coil or so and see how it looks. Yeah, it's a PITA to have to install and remove the springs, but you can't make them LONGER...
  13. niceguyede
    niceguyede
    from dallas
    But, by the time you get done you're an expert at your suspension!!
  14. niceguyede
    niceguyede
    from dallas
    you shoulda sold me that car!
  15. tjwash
    tjwash
    from Tucson
    I lowered my '64 by cutting all four springs and it rides great still..of course i do have brand new shocks, and hotchkis kit to help with the handling, but if you take your time it will be fine. I used the heavy duty springs.
  16. nwbhotrod
    nwbhotrod
    from wash state
    Just get the old hot wrench out heat them up reel good. Slam that ***** in the weeds
  17. ryno
    ryno
    Start thinking about your drive shaft also
    Slip joint and new carrier bearings
  18. Sprout
    Sprout
  19. A Rodder
    A Rodder
    I've heated up several, they still ride nice. Cutting them is a better choice though.
  20. nwbhotrod
    nwbhotrod
    from wash state
    3 inch lowering springs on my 62 impala you have to watch the drive shaft hitting the floor pan
  21. Or you could be a complete rebel, and leave that thing in the air as mother GM intended....or in my case, put it back up in the air. It sure does save the breast bone.
  22. BFROSTY
    BFROSTY
    from Indiana
    Does any one have any pictures of a 64 with 2 full wraps cut? I don't care about the ride cause it won't be a permanent stance, just worried about cutting to much it rides the frame or kicks the camber out.
  23. slammed
    slammed
    Shimming the upper a-arms will happen when taking out so much from the coils. The lowers will 'kick out' the ball joint, so the uppers will have to be spaced out to bring it back to square. There is a special cross bar for this ($) A lot of guys here on the HAMB have cut 2 full wraps from these '58-'64's with out too much fuss. Good, shorter quality ft shocks are a must for helping the ride. If your car does not have a ft sway bar, add one later. Even a skinny stocker is better than nothing. 2 full coils is roughly 4" drop. Depends on the coils age and spec (wagon w/air, 6 banger, ect)
  24. BFROSTY
    BFROSTY
    from Indiana
    It has a sway bar, I just wanna drop it so I can cruise the rest I the summer then it's getting disk conv and full air this winter. Thanks for the help!
  25. newstranger
    newstranger
    3" drop coils from JAMCO... Header dumps s****e every once in awhile, but I'm switching to ram horn exhaust manifolds soon, so that won't be an issue for long.[​IMG]
  26. pasadenahotrod
    pasadenahotrod
    from Texas
    How about the good old fashioned way with brand new springs from your local auto parts store? Go to the store, ask to see the MOOG spring catalog. Look up your car. Go to the back of the book where you will find sections listing the spring styles, find your spring part numbers in the listings. Now go up or down from there looking for springs with same wire size, similar spring rate, but shorter in length. Order them, install with shorter shocks and you have a good ride and NEW springs.
  27. slammed
    slammed
    Ah yes, in the OP's post he wants to cut the old ones, THEN save up and buy new, made to order springs. The shorter shocks advice is there too.
