Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. BarryA
    BarryA
    That is really impressive Hooli! I have to scratch build a 33/34 body soon and will definitely be looking to the books and DVD's I have from Lazze when I get onto it.
    Initially the car had a 'glass body and a shorter wheelbase than it has now - the upswept rear was the only way I could get proportions looking good and not too heavy/stumpy in the rear. I have since added another 8" in the centre of the chassis which improves the overall balance further.
    This thing is a bit of a mixed bag and will have other Euro inspired influences - I hope it all works. Planning of doing some LSR runs with it at this event so I need to hurry!!
    http://www.speedweeksa.com/
  2. 56premiere
    56premiere
    Here is one that is our area built by the owner. All built over bucks and with mostly hand made tools I was told Jack
  3. I've been building a '40 Ford Coupe for myself in my spare time. It came with a sbc adapted to a '39 trans. It will stay till I get the appropriate motor in it. A FORD of course. But in the mean time I would like to drive it and I have visions of it overheating so I decided I will louver the hood and make new inner fender panels and louver them.
    The originals where in pretty sad shape. I laid some paper down and sketched the outline, Cut the paper pattern and transferred it on to a piece of metal and tipped the edges to match the original. Mounted them and trimmed some more then laid out the louvers and punched them.
  4. donc1
    donc1
    from Oakville
    Very cool!
    What gauge steel on that coupe?
  5. 48stude
    48stude
    Looks Great Keith !! Bill
  6. donc1
    donc1
    from Oakville
    I'm building a 66 batmobile.....took about a month to do this front clip.
  7. donc1
    donc1
    from Oakville
    The twin front canopy/windshield cowls were about the most time consuming pieces to make....reverse curves-[​IMG]
  8. donc1
    donc1
    from Oakville
  9. gwarren007
    gwarren007
    Looking Good donc1!!!
  10. hudson hot rod
    hudson hot rod
    WOW! Now THAT is the coolest project I have seen in a long time! Please keep us updated!
  11. pimpin paint
    pimpin paint
    from so cal
    donc1,
    a major tip of the fedora to you for your build..........built from steel, not moulded from glassfibre:)
  12. BarryA
    BarryA
  13. Dyce
    Dyce
    Nice work Barry!!
  14. oztinbasher
    oztinbasher
    from oz
    Here's a 35 ford roadster back i'm making at the moment.
    and a model A decklid I did last week.
    Cheers Steve
  15. oldgoaly
    oldgoaly
    Nice BarryA and OZtin!
    Donc1, you and Jim Bailie are building Batmobiles! I think there is another shop also building one, are you guys just getting the Batman TV show????
    Thanks for posting your projects!!!
  16. BarryA
    BarryA
    Thanks Jeff & Terry!
  17. Irrational Metalworks
    Alliance Vendor
    from DFW
  18. bjinatj
    bjinatj
  19. MP&C
    MP&C
    OK, so I was bored this evening. I have a louver die set for my Lennox that was originally ordered and sized for .09 aluminum. Tonight I thought I'd try them out on some 18 gauge CRS to see how well it performed...
  20. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    What would be the difference between a set sized for .090 and 18 Gage? Shear clearance? Is that adjustable in your setup?
    I like the way the female die rotates on your setup to make a crisp end.
  21. MP&C
    MP&C
    I believe the difference would be the clearancing between the dies for the final "forming". But yes, there is adjustment to align/adjust the shear clearance.
  22. Irrational Metalworks
    Alliance Vendor
    from DFW
    That die set is the same size as one of my sets. Were those purchased from Neil Dunder? He built my latest set of dies. First rate quality! I have run louvers on everything from .032 alum. to .125 alum. with them. They also work great on 16 ga steel.
  23. MP&C
    MP&C
    Yes, got them from Neil. As you said, he makes some nice stuff. I think I'm going to be getting one of his CP style planishing hammers in the near future.....
  24. bjinatj
    bjinatj
  25. buickvalvenut
    buickvalvenut
    from Rialto
    looking good there.
  26. cederholm
    cederholm
    For a thread about metal, it sure gives me wood! :D
  27. bjinatj
    bjinatj
    I was told there is a lot of shape in this panel and it isn't an easy one to create. I feel they weren't kidding..
    I still need to do some planishing and defining of the bottom brake , but overall I am happy with it. I have to say that I made the panel on the first try, but I changed my mind and reassessed the shape so many times while building it I can't say that I really learned anything or could build another one any faster. I am guessing the lid should be a bit easier.
  28. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Nice job. That panel is harder to make than what it may look like to the casual observer, what with the reverse compound curve shape and the curved flanges at the edges.
  29. bjinatj
    bjinatj
    Thanks for the kind words, here is an update.
    Still working on her..
  30. oldgoaly
    oldgoaly
    google "The Key to Metal Bumping" I think it is online, it has been reprinted, pm or email me thru the website. There is no best book just many good ones.
