Is there an easy way to know which terminals are which on a HR106 Horn relay? I know there should be a horn, switch Thanks in advance for the help
They should be labeled H B S Horn, Battery, Switch Hmm, wait. Might be Horn, ****on, Solenoid (battery) Usually, when looking at the terminals, to horns on left, battery power center, horn ****on on right.
If it isn't a solid state relay you wouldn't be the first to carefully remove the cover and see what's connected to what.
That's a generic standard 4/5 pin relay, not a HR 106 horn relay. The original only has 3 connections on it.
