Can someone pls identify this pitman arm?
Discussion in 'The Hokey Ass Message Board' started by incogneto, Aug 18, 2013.
  1. incogneto
    incogneto
    from Australia
    I picked up this RHD spindle, drag link and pitman arm in a deal recently.
    It was described as a '34 setup.
    I thought that all pitman arms from 1932 to 1948 were splined. This however is tapered and keyway'd.
    Can anyone confirm what it is off?
    Thanks
  2. clem
    clem
    maybe it has been rheemed out and keyed to suit a different steering box.??????
  3. incogneto
    incogneto
    from Australia
    Thanks for your reply Clem.
    I forgot to mention - the tapered hole is smaller than splined shaft .
  4. Bruce Lancaster
    Bruce Lancaster
    The taper and spline are definitely non-Ford...this is either heavily modified (ball end is similar to '34 Ford) or non-Ford. Any numbers forged into it?
  5. incogneto
    incogneto
    from Australia
    Thanks for your reply Bruce.
    I have found no markings or numbers on the arm.
    I guess it's not early Ford.
