I have a Question on 1947 Ford
Discussion in 'The Hokey Ass Message Board' started by hotbrush_air_art, Aug 21, 2013.
  1. hotbrush_air_art
    hotbrush_air_art
    Hello I hope I can get a little info on this! I have a 47 Ford super delux sector box does any one know if I can remove the pitman arm and flip it as I need a bit more clearance for my oil pan. Are the splines on a taper fit or straight cut?
    Thank you...
  2. fastrnu
    fastrnu
    from shelton,wa
    They are tapered. It can be heated and bent then dropped in a bucket of lime to cool. After it is cooled it needs to be magnifluxed to check for cracks.
  3. hotbrush_air_art
    hotbrush_air_art
    Thank you Fastrnu!! That's what I thought too, I was Hoping for non taper lol..
  4. you should be able to re-taper the hole for the draglink from the other side
