Wiring diagram question
Discussion in 'The Hokey Ass Message Board' started by herbet99, Aug 23, 2013.
  1. herbet99
    herbet99
    from Central NJ
    In the attached image.. what item is designated by the symbol at the end of the red arrow?
    Thanks.
  2. SMOG_GUY
    SMOG_GUY
    from Dinuba
  3. 24riverview
    24riverview
    Probably just an open connector where Ford may have plugged something else in on different applications.
  4. chopped
    chopped
    For bonus points, what's the diagram from? The OP can't play.
  5. SMOG_GUY
    SMOG_GUY
    from Dinuba
    Capacitors or condensors are common on voltage regulators.
    Yes, it could be an used connector too.
    24riverview is probably right because you'd expect to see the symbol for a capacitor.
  6. SMOG_GUY
    SMOG_GUY
    from Dinuba
    Ford product.
  7. rocknrolldaddy
    rocknrolldaddy
    Condenser or capacitor.
  8. 24riverview
    24riverview
    Funny, I was gonna post to disregard my answer and listen to you. Worked on Ford dump trucks for years and they all had them. I say it's either the condenser/capacitor or the connector for it.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ford vote also
  10. SMOG_GUY
    SMOG_GUY
    from Dinuba
    You are a nice guy, 24riverview.
  11. herbet99
    herbet99
    from Central NJ
    Perhaps a connector for attaching some type of tester?
  12. SMOG_GUY
    SMOG_GUY
    from Dinuba
    The only tester I know would be a full-fielder tool. It plugs into the regulator connector and rules out the regulator as the culprit in a charging system problem. But not just one ckt.
    The capacitor's job has changed over the years.
    Early on it protected the points inside the regulator from arcing just like the condensor in a dist. protects points.
    Then it helped protect solid state devices from voltage spikes. Devices like early electronic ignition modules and solid state voltage regulators.
    Now capacitors, diodes and resistors (sometimes called self-commutating) keep voltage spikes out of computers.
    BTW in this case capacitor=condenser. But in no other case.
  13. Mike Miller
    Mike Miller
    The white wire that goes to the electric choke on a 60's 70's ford.
    That's my guess.
  14. 2racer
    2racer
    flux capacitor
  15. Ford blue blood
    Ford blue blood
    It is an open connector. Capacitors all had a proper schematic symbol for their locations.
  16. arvonian
    arvonian
    from Virginia
    Open connector, capacitor would have a symbol something like this: -II-
  17. Plus the capacitor body would be grounded...
  18. herbet99
    herbet99
    from Central NJ
    Based on another schematic I was reading.. could it be a radio noise suppression capacitor?
  19. SMOG_GUY
    SMOG_GUY
    from Dinuba
    The Ford guru said a loose connector.
    I said capacitor long time ago.
  20. Yep.
    That's not any recognized symbol for any component that I know of.
    Ill enter a guess of connector, but it should have a number.
  21. 40FordGuy
    40FordGuy
    Yep,....extra connection. That way, they don't have to make different wire harness.
    4TTRUK
  22. d2_willys
    d2_willys
    from Kansas
    My old Hudson Superjet wiring diagram has one like that. It is just a spare connector. I believe they were put for under the hood lights.
