Projects my henry j build
Discussion in 'The Hokey Ass Message Board' started by bulletproof1, Aug 20, 2013.
  1. bulletproof1
    bulletproof1
    from tulsa okla
    I've always wanted a henry j..this one was close to home and in my price range.october 2012 rashy and I headed to mustang okla.to pick it up. I didn't get started on it until jan this year. it was rough to say the least, I squared it up and started cutting.
  2. bulletproof1
    bulletproof1
    from tulsa okla
    after the floor was framed and the firewall was measured I started laying the sheet metal..this was my first time doing this..i bought a eastwood bead roller and borrowed rashys metal brake.
  3. bulletproof1
    bulletproof1
    from tulsa okla
    the front axle is a speedway kit with chevy spindles,a vega box.i mounted the brake pedals to the inside of the dash to keep the away from the heat and I like a clean firewall.
  4. bulletproof1
    bulletproof1
    from tulsa okla
    the roll cage bolts to the floor frames and has stingers that are welded to the frame .the seats also bolt through the floor frame work,
  5. Barn Hunter
    Barn Hunter
    Kewl....I'd like to do a J some day.:)
  6. bulletproof1
    bulletproof1
    from tulsa okla
    I narrowed a 9'' ford ,put a back brace on it and caged the center section where the third member bolts,this helps to keep the housing stiff. it has 350 gears,detroit locker, 31 spline shafts , explorer disc brakes, 1350 yoke.
    chris alston ladder bar kit with pan hard bar ,vari shock coil overs
  7. bulletproof1
    bulletproof1
    from tulsa okla
    trans is a coan power glide with 4200 stall,1350 slip yoke and cooler
  8. alumslot
    alumslot
    Great looking start. A friend of mine is just getting started with his J I'm going to show him your pictures as his has no floor either. We've got my floor in with new rocker panels and mounted to the frame still LOTS of rust repair still to do. Thanks again for the pictures and keep them coming.
    Jim
  9. bulletproof1
    bulletproof1
    from tulsa okla
    I mounted the battery in the drivers side rear fender area,the kill switch runs through the trunk,also put the trunk lid on a diet. there will be a speedo in the dash as well
  10. 1964countrysedan
    1964countrysedan
    from Texas
    Looking forward to more on the current Yahoo cup champion!
    Thanks
  11. captmullette
    captmullette
    nice build........ very good work
  12. Firefly
    Firefly
    Yeah - how cool is that! Congrats Mike :D
  13. good to see another HJ coming along
  14. blue 49
    blue 49
    from Iowa
    Looking very nice. I'm working on one too.
    Blue
  15. swade41
    swade41
    from Buffalo,NY
    So what about that super secrete engine ???????
  16. bulletproof1
    bulletproof1
    from tulsa okla
    fuel cell is a 16 gl RCI, using a fram race filter with a aeromotive SS pump.
    the back and side windows are lexan,i added a 1/2 lip to the sides so the bolts have room.
    tail lights are 56 chevys ,used a universal socket and made a plate for it to attach.
    radiator and fans where made by saldana racing products,
    front shocks are Q1A adjustables (90/10s)
  17. 4 pedals
    4 pedals
    from Nor Cal
    Nice clean work. Did you build the headers, too?
    Thanks,
    Devin
  18. bulletproof1
    bulletproof1
    from tulsa okla
    headers are patriot 55 chevys,,I added the 2 bolt ball and cone collectors,also had to "adjust" them a little..bent them inboard about an inch.
  19. SKULL ORCHARD
    SKULL ORCHARD
    from KS
    CAR LOOKS GOOD. HAMB DRAG KILLA, are YOU going on drag week? mark
  20. bulletproof1
    bulletproof1
    from tulsa okla
    yep the hamb drags was the shake down... tomorrow putting a new gas pedal in that will fully open the back barrels.should go a bit faster...
  21. SKULL ORCHARD
    SKULL ORCHARD
    from KS
  22. 28rpu
    28rpu
    Hey Bulletproof1, any more build pictures of your Henry J? Did you use somebody's roll cage kit? If so who's. Thanks
  23. flamedabone
    flamedabone
  24. Hemi j
    Hemi j
    from Colorado
    Looking good !
  25. Saxxon
    Saxxon
    Love J's...cool build
