59ab flathead question???
Discussion in 'The Hokey Ass Message Board' started by fnjunk, Aug 25, 2013.
  1. fnjunk
    fnjunk
    from Australia
    Just a quick one for you flathead experts I have a 59 ab flatty that was running a remote oil filter fed from the drivers side rear of the block and draining back near the dip stick.
    Can I block these off and run the engine without the filter or are these a must have?
    Thanks guys
  2. model.A.keith
    model.A.keith
    I run my 8BA without a filter, just change the oil a bit more often.......;)
    k
  3. fnjunk
    fnjunk
    from Australia
    Thanks Model.A.Keith I was a little worried I might block oil circulation if I didn't run one.
  4. 51custom
    51custom
    ^^^^^^^^ What he said....
    Jim
  5. DICK SPADARO
    DICK SPADARO
    Filter not necessary, two pipe plugs do the trick, dont crack the die cast oilpan dip stick mount.
  6. Merc cruzer
    Merc cruzer
    from Colorado
    Oil filters were an option on many of the early flatheads.
  7. flatcrazy
    flatcrazy
    Just keep the oil changed regularly. I don't run a filter.
  8. fnjunk
    fnjunk
    from Australia
    Thanks guys are there any exceptions?
    Only asking as a couple of guys have pm'd me tell me other wise and I'm a little gun shy /confused ???
  9. Thaplumbr
    Thaplumbr
    I'm running a 59ab flatty in my 48 F-1, plugged the return to the drain pan,and the port on the drivers side rear beneath the sending unit no problems at all!
  10. Dad's 1932
    Dad's 1932
    from Santa Rosa
    Post a picture of how it is plumbed . Mostly the back of the block .
  11. fnjunk
    fnjunk
    from Australia
    Ok Dads 32 will do when I get home tonight.
    Thanks
  12. 40FordGuy
    40FordGuy
    Just plug the two ports, as said above; Works great !
    4TTRUK
  13. Christom
    Christom
    Most old Ford set-ups are only byp*** filters anyway - not full flow. Just keep the oil clean and check for **** in it when you change it. A magnetic drain plug is always a good option too.
  14. fnjunk
    fnjunk
    from Australia
    Thanks guys for all the help.
  15. BDogCstms
    BDogCstms
    Magnetic Drain plug, change oil very frequently, no problems. Remember oil is cheap compared to the consequences.
